Need help on designing a good sub box or wall
Thanks guys for the feed back its always good to ask questions so since that design is a big fail on to the next one..........here are a couple of wall designs i was thinking about but want you all to pick one that will be good for me dis reguard the 38x28x36 cause I could go wider plus I have 4 18's one just need to be reconed so leave some thoughts and PLEASE NO NEGATIVE STUFF ....JOE X .....LOL but here they are:[{IMG}20140415_164037_zps0h8xuxhk.jpg
Look at 3 8" or 2 10" aero ports to. Both roughly the same port area but might give more volume then the 6 6" ports.
can use sonotube and make flares. Add strength to them with resin and bracing. Bracing could be done in a way that helps brace the box as well.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   1 Member, 0 Anonymous, 1275 Guests (See full list)
