No the output that I get the distortion from is on the eq. Not the hu. It has front, rear, and sub outputs on the hu. The front is going to the eq, then from eq to amps. Tested the rcas coming from the hu its clean on 40hz and 1000hz. But once I plug rcas to the eq, its clean on all the eq outputs except the one rca out to subs. The other sub rca is clean but the other is showing signal, distortion, then 40hz. All others show signal, 40hz, then distortion.
03 tahoe z71
4 death penalty 18s
2 ampere audio 3800s @ .5 each
18v
156.7 @ 35hz
158.5 @ 50hz
Tested both sides of the rcas in all the testing. Just the one does that. That's why I think the eq may have a bad output.
Edited by jeffrm
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
If one rca is clean and the other is dirty. Just use the clean rca with a no signal loss y adapter. Problem soled.
truthsayer
^^^^ did that and now all is good. Thanks everyone for the help.
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
