corey7733 Posted April 10, 2014 Author Report Posted April 10, 2014 ok but let's say they are, is the wiring going to be much simpler then I'm imagining? I'll find out if I can do this with these amps
BoomZoom808 Posted April 10, 2014 Report Posted April 10, 2014 Each coil would be wired to each amp think of the coil as a speaker by itself. 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
corey7733 Posted April 10, 2014 Author Report Posted April 10, 2014 ok. so these amps are most likely not strap able, but they may work each one running its own voice coil.? If i were to try this, would it harm an amp? I have read that it will not hurt the sub
jarrius Posted April 10, 2014 Report Posted April 10, 2014 It will not harm the amps as long as you don't run them under there rates ohm load and run them with low voltage. Also make sure both amps are the same before trying this. If you do it also you will need to match both amps rms output perfectly. If not say by by to your sub. 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
