Flared port clearance
Cj Kumz
Hey people got a question. Ok on average most people advice having the port diameter as your minimum clearance distance both in the box and outside. I hope I'm on the right track lol.. So question is when you flare the port ends, does the clearance reduce or increase??
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
5.5 cubic feet box with 10 inch port @ 38hz
I live to hear the Bass drop!!!
Rule of thumb is still port diameter. Not the flared section diameter though.
you could possibly get away with being a little closer then the rule of thumb suggest but only testing will tell.
biggest risk is port noise smallest risk is change in tuning freq due to lack of spacing
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Ok thanks alot. Uhhhmmm so for a 10 inch port could I get away with a 7 inch clearance both ends??
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
Yeah I think you would be fine. You can probably get away with as little as half the diameter of the port if you had to, especially if its flared.
Builds:
I'm sure the bigger the diameter and the better/effective the flare the clearance would go down in perspective with the diameter of the port though. So like with a 10" port and a good sized flare you could go down to say half the diameter so 5" of clearance per side with less chance of an effect on tuning, port noise, or freq band changes.
however with say a 6" port with a good flare going down to half the diameter might be more likely to have issues then the 10" port. Maybe the least amount of clearance for the 6" port would be 4-5".
would most likely also depend on if you at the higher end of required port area or lower end of required port area.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • 4 weeks later...
I have been using my 10 inch port now for a week and it doesn't sound that bad but I know it can sound better. I am using 5 inch clearance in the box and 7 inches outside. I have not yet flared the ports though. There damn thick lol.. Without the flares should I stay within the 10 inch clearance??
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
With out flares it would help to have the proper clearance.
also use more clearance inside the box to see how that works out for you.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Hey I just tried out having 11inch clearance inside the box and I got really great results. More air is flowing and very smooth. Only issue is I have 7 inches clearance outside. So I think ama flare jst the outside. Thanks a lot for info, it helped me a lot. Cheers
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
Push the port into the box 1" more.
it would give you 10" clearance inside and 8" outside.
at least round off the inside port. Get some 1" to 1 1/2" pipe insulation from home depot or lowes and put it on the edge of the port. Glue it in place with a hot glue gun or something.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Post pics to.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 3493 Guests (See full list)
