Car Audio Newbie needs help selecting an appropriate amp!
Techno_Allah
Alright, first off I know NOTHING about Car Audio and setups so I won't be able to answer any super technical terms or even basic entry level stuff so bear with me.
I'm here in America (I live abroad) and a friend of a friend has this (http://www.amazon.com/Kicker-11S15L7D2-Solo-Baric-Car-Subwoofer/dp/B004MX8KHQ/ref=pd_cp_e_0) for sale. He's selling it because he got another pair of subs or something and I can get this, still new one for around $250.
While I've already pretty much bought it and about to bring it back home with me, I need help in selecting an approriate amplifier to play this thing properly. With something this costly, I know it isn't as easy as just matching watts on the speaker to watts what the amplifier can push, there's alot of technical stuff that goes along with this from what I've seen and I don't want to damage or blow this thing with an over powered or underpowered amp.
Also keep in mind that in the near future I might add another identical subwoofer to the system I'm trying to create so an amp that could run the both of 'em would be nice..or is it just sensible to run a seperate amplifier for both woofers?
Hope I made some sort of sense. Cheers.
-Copied from the Features section-
Tough-as-nails steel basket with perimeter venting for toughness 2- or 4-Ohm dual voice coil IMPEDANCE (Ohms) - 2 or 4 DVC POWER WATTS (peak/RMS) - 2000/1000 SENSITIVITY (dB 1w/1m) - 89.4
That's the amp in question. Hope that helped answer your question. I'm at a total loss when it comes to this technical stuff.
OK so dual 2 ohm. So at first you can only run the sub at 1 ohm or 4. And when you add the second one you should run it at 2 ohms. Just find and amp that can do the power you need at 2 ohms. When you get the second sub make sure it has the same dual 2 ohm configuration. And about running each sub with its own amp will only work if you have 2 of the same amps and gain match them, otherwise one sub will over power the other.
I'm still confused as to what I should be looking for in an Amplifier but atleast I know what sort of Woofer I've on my hands. A 'dual 2ohm' which I should be running at 1...or 4 ohm. I was more hoping to be advised on a specifc brand of amp that would work best with my speaker based off of user opinion and such...but I guess at this point not being able to discern what's good or bad at a technical level, I should just get a decent 2ohm amp and be satisfied.
Thanks for the help, I'll press forward with what you told me.
any quality brand will do just fine. what is your price range on an amp?
Fi Team 18's (4)
Crossfire 16k
Crossfire 400.4 & 800.4
Pioneer AVH-X491bhs
140ah cmax
CES 320's (2)
well what's your budget on amp?
id suggest either
http://www.sonicelectronix.com/item_67936_Hifonics-BRX2400.1D-Brutus-BRX-2400.1D.html
or
http://www.sonicelectronix.com/item_76262_Hifonics-X2600.1D.html
but everyone will have their opinion on which would be best.
just make sure which ever amp you decide on, that it can do about 2,000 wats rms at 2 ohms. that will leave you plenty of room for when you decide to add a second sub.
Fi Team 18's (4)
Crossfire 16k
Pioneer AVH-X491bhs
140ah cmax
CES 320's (2)
I'll be the dick... He said good quality amp not pos that draws a shit load of power and does not do rated rms.
These 2 amps wil be your best bet unless you buy used. Both these amps put out more then rated power PROVEN!!! But you will need to upgrade your electrical with any 2k amp.
https://www.soundqubed.com/Q1-2200D_p_31.html
http://www.c2audio.com/C2Audio-Recon-16-Amp
Edit: also look at the soundqubed subs. There amassing subs will last along time and are just all around better (IMO) then those kickers and they are also cheaper and NEW ^_^
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
  • Who's Online   0 Members, 0 Anonymous, 659 Guests (See full list)
