2011 hyundai genesis build help, thanks in advance!
there is always something, its called custom install,
you may need to contact some local shops and see if they can install a h/u
ya i know im just not confident about my ability to fab something up, do you know of any reputable shops in the chicago land area? and do you just not recommend the line out converters?
What loc do you have
Some do a pair of speaker, well most do
But if you running all stock everything
Now
Why not switch out the h/u and save the money on loc
im using PAC SNI 35 adjustable 2 channel line out converter's, im running a stock HU because as far as im aware there is nothing available for my car as far as dash monting kits go, unless im mistaken
Don't use the sni 35. I just ripped mine out of my car because how bad it sucked. Horrible sound quility and does not even put out 1v outs for the rca's
damn. what do you recommend
Did you check the trunk on the right side behind the panel for the amp?
yep, theres no amp in the car
if anybody knows any reputable shops in my area please let me know im in chicagos northwest suburbs
OR could I retain my stock head unit and run both amps off the audio control epicenter plus?
Hmm what I'm seeing on my rear deck just be another speaker then, I have a single disc player so i have the most basic audio system the car comes with there is no amp in my car
By the way if I did have the amp and sub what is the significance of that? Easier to wire or something?
Could anyone tell me if I could run to amps off te epicenter plus?
  • Who's Online   1 Member, 0 Anonymous, 516 Guests (See full list)
