2011 hyundai genesis build help, thanks in advance!
whats up everyone, im about to start a build on my 2011 Hyundai genesis.
the equipment ill be running is as follows
- 2 12" dc level 4's on an sound qu 2200d
- speakers will consist of componets up front, which are sound qu QC's and rear doors ill be running QP's. speakers will be powered by a sound qu Q4 120
- im going to be on stock electrical for the time being. 110 amp alt and a decent battery, soon will be upgrading to xs power d4900
this car is the first car I have where I will be keeping the stock head unit.
this is the part where I need a bit of help, I have two PAC SNI 35 adjustable 2 channel line out converter's
question number one is, will these line out converters work?
question number two is, can I run more than one line out converter?
I will be using 2 amps so how should I go about running these?
and finally question number three is, where should I wire in the line out converters?
thanks in advance!
Sedan or coupe
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
sorry about that, sedan!
basic 7 speaker setup. no tech package or anything like that, no nav either
Some have 7 outputs from h/u and others 5
If 5 t-in before the front split and run 1 loc from each speaker
And piggy back the rears for sub(so 4 loc are needed)
Or if yours is the 7 with sub idd run an epicentre
Side note why you going sq everything and then lvl4 and not hdc3
ok, there is a stock sub in the car but no stock amp, so i would need to run a loc for each of the speakers? i currently have 2 locs on hand. would i put them in the dash? then run the rca's back to the amps?
also that'd be 4 sets of rca's.. but the amps only have 1 input for rca's each correct?
i just feel super confused about this i need to be treated like a child being explained something for the first time lol, in detail and broken down step by step haha sorry if thats too much to ask.
as far as why i have the level 4's its only because i have had them for 2 years in previous set ups as well as the 2200. just decided to go with sq speakers for this car as well
What loc do you have
Some do a pair of speaker, well most do
But if you running all stock everything
Now
Why not switch out the h/u and save the money on loc
Now
im using PAC SNI 35 adjustable 2 channel line out converter's, im running a stock HU because as far as im aware there is nothing available for my car as far as dash monting kits go, unless im mistaken
Now
Don't use the sni 35. I just ripped mine out of my car because how bad it sucked. Horrible sound quility and does not even put out 1v outs for the rca's
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
  • Who's Online   1 Member, 0 Anonymous, 537 Guests (See full list)
