Joe X Posted April 21, 2014 Report Posted April 21, 2014 2 subs and an a 5 inch port will fit on the front? You gave the dimensions to work with, take measurements and give me some feedback, the box is meant to fire forward towards the cabin.
stuntman05 Posted April 21, 2014 Author Report Posted April 21, 2014 Ok thanks. I ll try it and let u know
LoudPackRacing Posted August 31, 2015 Report Posted August 31, 2015 This can be done, power: to subs rated, amp subsonic filter to 28Hz, port clearance 4 3/4" figure is just an assembly guide, build a cardboard dummy box to see if it will fit in it's way in: CN you design me a suv box for 2 12" l7s tuned to 34hz max demons ions are 38width 22height 22depth subs up port forward.
Joe X Posted September 1, 2015 Report Posted September 1, 2015 Sure, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 4 1/2", figure is just an assembly guide:
LoudPackRacing Posted September 1, 2015 Report Posted September 1, 2015 Sure, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 4 1/2", figure is just an assembly guide: Are the 45's necessary? If so how wide should they be?
LoudPackRacing Posted September 5, 2015 Report Posted September 5, 2015 Do them like this: One more question, let's say I'm building a wall how do you decide how wide to make your 45's or does it matter?
LoudPackRacing Posted September 24, 2015 Report Posted September 24, 2015 This can be done, power: to subs rated, amp subsonic filter to 28Hz, port clearance 4 3/4" figure is just an assembly guide, build a cardboard dummy box to see if it will fit in it's way in: Can you design me one like this with max deminsions being w35 H14.5 and depth 28.5 tuned to 32hz and 5 cu.ft.
Joe X Posted September 25, 2015 Report Posted September 25, 2015 Closest as possible to your max dims, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 6", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
LoudPackRacing Posted November 3, 2015 Report Posted November 3, 2015 Closest as possible to your max dims, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 6", figure is just an assembly guide: NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. I plan on using 2 Rockford r750-1d . They put out around 920 @1 ohm will this enclosure still be efficient?
