Kyblack76 Posted April 18, 2014 Report Posted April 18, 2014 320 is a fave of mine. Thats by many makers. I like a high output, and a strong idle. Of course, id love 300 at idle and 400 at rev, but, that isnt how it happens. If your crank pulley makes your turn on low, then do a smaller pulley,.. there are things you can do, to see what you want. Like Chris (snowdrifter) above said....... Belt wrap, turn on, belt ribs, contact, pulley size (on the alt, and the crank) and many other factors come into play. There is not PERFECT solution/gear. I do read "just put the biggest you can fit" over and over, and then, read "I just put a HO alt in, and i get a battery light when im sitting at a light?" OVER and over... I know of a alt that does over 400 amps right now...........(well over in fact) And, i wouldnt put it in MY build, if it was given to me. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
cgrez33 Posted April 18, 2014 Author Report Posted April 18, 2014 Output Voltage 14.8 Idle Amperage 225 Hot Idle Amperage @ 200ºF 175 Max Amperage 300 Hot Max Amperage @ 200ºF 250 DC 300SPX Seems to be the best upgrade for my vehicle but it's also out of stock and only 30 bucks more than my current alternator. Current Build: 1999 Tahoe #ComingSoon Previous Build(s): Crossfire Magnum 5k Pontiac G6 GT
Kyblack76 Posted April 18, 2014 Report Posted April 18, 2014 what is your idle? mine is 650rpm (motor speed, not alt) SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
cgrez33 Posted April 18, 2014 Author Report Posted April 18, 2014 I sit about the same 650-700 idle. Current Build: 1999 Tahoe #ComingSoon Previous Build(s): Crossfire Magnum 5k Pontiac G6 GT
