Getting louder off 2 SMD's?
I've got 2 18" SMD's in a mk4 golf in a wall tuned to around 26-27hz. The box is 21cuft but has been reduced to around 14cuft using 45's (ready for a 3rd one if i decide to get one). I've got 2 210a alternators at 15v and using 4 yellow top batteries - not really used. the voltage is fine, stays around 14.3-14.6 full tilt. My most recent scores are:
40hz - 150.9
33hz - 153.9
25hz - 152.7
20hz - 150.6
What can i do to get louder and get more violent hair tricks? I was expecting a 155 out of this so maybe I'm not doing something right? It's running 5k per sub. Was thinking of raising the tuning to 33 or 34 hz? Would that help scores and sound louder to the ear or not?
its worth a try and easy with a wood block
which amplifier do you have on your smds?
the higher you tune the lmore low end your Gonna lose. personally i like lower tunes over annoying 45hz plus tunes. but if your chasing numbers you need a higher tune.
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
Tune it at close to 30-32 hz you will love it !!! I was running two 18 inch SMD with four T2500. You will get good hair tricks with good score also !!!!
"Easy" 155 if you tune to 34Hz, still low enough for most low songs except C&S.
If you notice that the subwoofers can take more, enlarge the enclosure a bit.
And do the usual SPL tricks.
I'm running GZPA 4k's strapped together to give 10k, then split over the 2 subs
I only listen to music between 20hz and 44 hz or so, so would prefer it still being able to play lows nicely. and the scores are with driver door open and mic on the passenger head rest - PD format in the UK
I'll try to raise the tuning and see if that helps. Anything else?
  • Who's Online   0 Members, 0 Anonymous, 3203 Guests (See full list)
