Charging a battery
I know it should be simple but I've never done this so better to ask before I blow things up haha
Ok so I want to know how to go about charging my batteries in my truck!!
1 agm under the hood and one in the cab of the truck agm also! Both connected by two runs of kunu concept 0 gage positive! Singer 340amp alty to keep the system happy!
Would I just throw the charger on the front battery and start charging or charge batteries separately? Do I leave the amps connected to the batteries? Or disconnect before charging?
Last but not least which charger do I buy?
Leave all your batteries connected. They will all charge at once
As for chargers: This is a really nice one
http://www.griotsgarage.com/product/microprocessor-controlled+battery+charger-maintainer.do
Is it a smart charger, dont want to be over charging. You leave everything connected btw
Edit: just read the whole post
I have this diehard battery charger/maintainer it is only 3a trickle charger it is great for only 50$ it auto goes into maintain mode when fully charger
06 monte carlo
2 12 rockford p3s
soundstream rubicon 2500
crescendo audio mezzo 6.5
ct sounds 125.4
execution audio and shca wiring
2 xs d3400 on stock alt
Yup. Set it and forget it.
It will charge, go into float mode, and if needed to a drain/charge cycle to recondition your batteries. All automatic
Once every week or two should be plenty. You're just looking to top of the residual that your alternator doesn't
I am also new to this. I have lead acid up front and hc2400 in back. Is it the same procedure? Both batteries read the same at rest and when the car is run running. 14.4 to 14.8v. Is my alt not charging my hc2400 all the way up?
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
Unless you drive for 6-8 hours straight your alts will never fully charge your battery.
Yes it is the same procedure as far as charging goes. And being that you have 2 different battery constructions in your car, you'd want it plugged in whenever is convenient. Your front "normal" battery will have a lower resting voltage than your kinetik and as such, will discharge your rear battery any time the car is off
  • Who's Online   0 Members, 0 Anonymous, 6869 Guests (See full list)
