PortSideAudio Posted April 25, 2014 Report Posted April 25, 2014 Hey guys, I'm taking on the task of installing a HDC3.118 in my corolla in a 6 cubic foot box. So here is the wiring I will be installing (critique as you feel necessary) Knu 0AWG from battery to second XS power NVX battery isolator 4AWG going off XS to Q4-120 and Q1-2200 Fuse for 0AWG then another fuse for each 4AWG power wire (if I remember correctly the fuses are 250A and 150A) Either 8AWG or 10AWG speaker wire (the sub has 10AWG direct leads) To amps running coaxial RCAs (I was told Soundqubed uses single input not differential) Problems I can see arising:The box takes up most of my trunk, I will have very little room for amp and battery (amps may have to end up being outside the trunk *thoughts on this?*) If you can think of any other problems please tell me So what I'm asking for:General critique over everything above. Is there anything major I should avoid doing in order to ensure safety and functionality? Do you guys have any tricks to keep this build clean and easier to work with? 2002 Toyota Corolla Pioneer DEH-80PRS Soundqubed Q1-2200d Soundqubed HDC3.118 Soundqubed Q4-120 Alpine SPR-60 Alpine SPR-60C
