the .3 difference isnt much at all. some subs displace that with magnets alone. and if you add 45s to the corners. the amount of output you will lose isnt anything to worry about. but if your doing a 3.2 box (net).dont do 45s you'll lose allot more. also if you run magnet out you'll keep the true tune of the box
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
A smaller box will allow mechanical control over the sub if over powering it helps prevent damage from over exertion. Doesn't do anything for heat though.
bigger boxes tend to be more efficient. Meaning less power same out put basically.
as for your box idea I can say 3.2cuft net per subs should be just fine. However you haven't mentioned port area. To small of a port and you get port noise and a poor freq response.
for 15s (pending Xmas) you usualt want at least a 6" round port per sub or roughly 40-50sq" of port area for a slot port.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 320 Guests (See full list)
