Will an alternator "shield" alter performance?
Well I recently acquired a 1992 Lexus sc400 and I absolutely love it. It is a great, smooth car that should be extremely reliable for the future but I have one problem with it:
The engine is designed to where the power steering pump is right above the alternator and quite often, gaskets in the pump or the reservoir leak fluid right onto the alternator and fry it.
Well as I don't want to drop $400+ on a h/o alternator to have it destroyed I have been pondering the idea of a "guard" of sorts.
I found a guy on ebay who makes some where it basically looks like a Clorox bottle with attachment bolts.
http://www.ebay.com/itm/Alternator-Shield-Kit-UZ-1991-2000-Lexus-SC400-Soarer-/291130997486?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ASC400&hash=item43c8c27aee&vxp=mtr
Now, I would never pay for something as cheap looking as that (I would much rather make my own) but my main question is: is it plausible?
I assume alternators need some amount of openness to allow for proper cooling but would a DIY shield affect performance/shorten the lifespan of an alternator?
I am sure you can understand my concern for protection of such an expensive piece of equipment and as of now I am still in the research phase ...
So is the Shield a good idea?
Thanks
Dorm room setup:
SQ SDC2.5 12" @ 8 ohms
Klipsch 300 watt home theater sub amp
Marantz 1030 amplifier
Future car build:
Audio Technix 1200.1d
Fi SSD 12 w/ cooling and flatwind coil
6th order dual reflex enclosure
A shield would decrease airflow, increase the temp of the alt, and decrease output a tad.. but its worth saving an alt IMO
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
I would just fix the power steering pump issue.
truthsayer
Well the thing is in my mind there is no such thing as a permanent "fix". I could always replace it (I don't need to now as it's not leaking) but even the slightest chance of a leak will always bug the hell out of me. Maybe I am just overly cautious but I would rather take the overly safe route.
Dorm room setup:
Future car build:
Totally agree, I would think the performance trade off would not overcome the value of protection. So do you think the shield would damage the alt, or would it simply decrease performance?
Dorm room setup:
Future car build:
Meh.. in my PERSONALLY opinion.. just hinder output. Thats is considering the alt isn't wrapped mainly in shielding.
The ebay link you posted would concern me.
LMFAO so true
:blush:
Also of note: Higher heat will reduce the light of an alt
See if you can mitigate the problem by keeping fresh p/s fluid in there.
It's braindead easy to change. I do it every oil change
Take a turkey baster, suck out the old fluid in the reservoir, refill with new fluid. Boom done lol
Also: You sure it's the power steering pump and not the water pump? Pretty common for water pumps on those to go out. Power steering - not so much.
As for the water pump... Preventative maintenance: Coolant every 2 years(yes, 2 years. I don't care what the manual says. 2 years.). Gaskets are weak, old coolant gets acidic, eats the gasket, leaks. You'll find that a lot of "problems" in cars can often be eliminated with proper maintenance.
All this does is replaces the fluid in the reservoir there's still plenty of fluid in the pump, rack, and lines. I use a p/s flush machine that works while engine running to flush old fluid out.
-Dan Kasun
05' Dodge Ram 1500 QCSB Hemi Blow-thru build in progress.
2 RD HW18's, RD D9, 5 Deka 9a31's, 6th order blow-thru box, Eclipse 7200mkii HU, 140' Knu Kollossus wire. DC Power 270xp Alt, Etc.
That's why you do it more than once lol
I doubt OP has a flushing machine and TBH there's no reason to pay a shop to do it.
  • Who's Online   0 Members, 0 Anonymous, 4447 Guests (See full list)
