Trying to fix epic ground loop!
I changed my rear battery and amp grounds from the seat belt bolt (yes I can't believe I did that in the first place) to grounding my battery to the frame and my 2 amps to my rear battery. Now I have much more stable voltage and an incredible ground loop! The noise happens when I apply the brake of shift gears and it is very loud. I tried to ground the rcas on both amps to different locations and no luck. Can someone give me an idea where to start or what to do to fix this, thanks!!
2017 Honda Accord Touring
Build coming soon
After removing the mid/hi amp ground, problem was gone. I put a new ring terminal on it, reconnected it but nothing changed. Seems to be in that circuit somewhere. What else to check?
Build coming soon
Are both of your amps grounded to same place?
Have you:
- grounded alt case to frame
- front battery to frame
- add hu ground to chassis
- chassis to frame ground
All grounds 1/0 or bigger except hu of course.
Ground it somewhere else and use sandpaper or steel brush .... that's first thought
how close is your battery to amp ?
how are your rca's ran ? if they cross any power it must be a 90 degrees or 18" from higher power .
is your battery grounded with correct size wire ?
No 1 But me paid for this stuff and NO FREEBIES so no brand names (No Free Advertisement )
A SQ head unit
6 5.25
2 X 6x9s
7804
P400.4
4001D
1 34s (Maybe time to change brand)
4 X 15" s
!/0 @ 2/0 OFC Wiring
:morepower1: :morepower1: :morepower1: :morepower1:
ill say it like i always say it. F##K the DD-1. I don't care if you or anyone buys one. (well i do, but that isn't my point) Get an O-scope in the very minimum and learn how to use it or you are just guessing your settings like every other noob. :) once you master the O-scope then step up to a DD-1 or even better a DD-1 Plus.
That's a problem ground each amp to their own ground source
A SQ head unit
6 5.25
2 X 6x9s
7804
P400.4
4001D
4 X 15" s
Both amps are within 12" to the battery, rcas are ran the ought the center of the vehicle (and now further from ground,power wire than before) battery is run with 1/0.
Build coming soon
Build coming soon
  • Who's Online   0 Members, 0 Anonymous, 6869 Guests (See full list)
