max785 Posted May 2, 2014 Report Posted May 2, 2014 Hi,I want to add my old aq1200d with 1 sa-12" to my system. I'm running an r600-4d for my componants. I have 1 run of knu kfc 4 gauge.Should I change all my wiring for 1 0 gauge and use a distribution block to split in 2 4 gauge or run another 4 gauge wire to the back of the car ?? 2001 civic dx 2 X sa12's " 1 X aq1200d Knukonceptz 4 gauge , rca
BLuejoules Posted May 2, 2014 Report Posted May 2, 2014 I would do a run of 1/0 then use a distro block personally. IG: devinthydude
hazestorm23 Posted May 2, 2014 Report Posted May 2, 2014 I would run 0 gauge that way in the future it leaves room for upgrade just get a distribution block and from there feed the amps that way you have as much current flowing as possible to the back
max785 Posted May 3, 2014 Author Report Posted May 3, 2014 Ok I will buy some 0 gauge then.Do I need a fuse near the battery if the distribution block is already fused with the proper fuses ? 2001 civic dx 2 X sa12's " 1 X aq1200d Knukonceptz 4 gauge , rca
Miguels Posted May 3, 2014 Report Posted May 3, 2014 you need one before the battery on both ends my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
