Have 2 subs but they move opposite of eachother
sounds like you have an install problem..
That's all I got.
2004 Grand Prix GT
(2) 12" RE XXXs (04/05 XBL^2)
5 cu. ft tuned @ 35 Hz
MMATS HD4000.05
MMATS SQ4100
Infinity Kappa components
Juice Box black cherry
Duralast platinum group 34
1/0 KNU OFC, 2/0 welding
Singer 250A
Then go and get a 1.5v battery and touch the terminals to it (you may need some short wire) to be able to find which way all the coils need to be wired to have it push the cone out.
i think i know what you mean with the battery, like test each terminal on the one sub seperate to see if its just one side that could be mixed up, ill try that when i can find a battery
Subs - Dual RE Audio SXX v2 15D4 wired at 1 ohm
Door Speakers - RE REX 5x7/6x9
Battery - Kinetik HC 2000
Sub Amp - Crescendo BC2000
Door Amp - Alpine MRP-F300
Head Unit - Pioneer DEH-X8600BS
maybe the factory swapped the + and - by accident
post a diagram how you wired it
http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/1-DVC-2-ohm-mono-low-imp.jpg this is how the subs are wired now,each sub has this same wiring going to my amp
i suck at using forums btw as you can tell with my hack job replys
You said you have two subs but the diagram you posted is for one sub. If that is what you used to wire it I'm really confused or maybe it was just an error.
both of my subs have the same wiring as the one sub in that picture, its the first one i found
Out of phase
Wired wrong at sub
Switch positive and negative on one...problem solved
i checked both subs they are both wired correct, the only way theyd be wrong is if the manufactuer mixed the + and -
  • Who's Online   0 Members, 0 Anonymous, 751 Guests (See full list)
