Smilies cuts off.. Sub problem?
AASMDBASS
OP still hasn't answered if the amp is going into protect or if its just shutting off altogether.
Cant do the testing at my house due to pissing off the neighbors so I'll do it ASAP... Can you give me insight as to what the problem could be with either scenario (protect, or shutting off completely)?... And how exactly would I know if it's in protect, or shut off completely?
Pioneer DEH 80PRS HU
Ascendant Audio SMD 18"
Audioque 3500.1D
XS Power D3100
Rockford T1 components
Rockford P400X4
Theres a little light on the amp that says protect or protect mode. and if it goes into protect mode that light will be lit. and if the amp just shuts off completly no light will be lit up on the amp
2004 Grand Marquis
AA Mayhem 18
Crescendo 3500d
6.5's AQ Pro Audio
AQ Super Tweets
Image Dynamics 6x9
Soundqubed 125.4
MB Quart 80.4
144.2 db
GONZO
2013 Chrysler 300S
Granite Crystal Metallic Exterior
Inferno Red Interior
5.7 HEMI AWD
LMI Air Hammer Intake
Corsa exhaust
Custom Tune
Ok, I can CONFIRM that the amp is going into protect... What does this mean in relation to my problem?
Audioque 3500.1D
XS Power D3100
Rockford P400X4
I wanna say most likely the gain is to high. Even if your gain is only half way it can still be to high. You need to match the output of your deck to the output of the amp so there is no clipping. Steve meade has the tool to do this and works great. But in the mean time try putting the gain to 1/4 up instead of halfway and see if the amp still goes into protect mode. It may not sound as loud, but to know your not clipping is a big relief especially when you have expensive equipment cause clipping can take a big toll on it.
2004 Grand Marquis
AA Mayhem 18
Crescendo 3500d
6.5's AQ Pro Audio
AQ Super Tweets
Image Dynamics 6x9
Soundqubed 125.4
MB Quart 80.4
144.2 db
GONZO
2013 Chrysler 300S
5.7 HEMI AWD
Corsa exhaust
Custom Tune
easy way to test for clipping. theres a red light on the wired knob that comes with all audioque amps. if its solid red, you're probably clipping.
What about the other issue that is cause the sub to go crazy at times... I've checked the coils on the sub they are good...
Audioque 3500.1D
XS Power D3100
Rockford P400X4
I don't trust that light for 1 second... I've had that light come on when at a low volume with the knob all the way down... Also, Audioque knobs go bad... A lot... I've replaced mine 3 times and 2 times on the 2200 I had
Audioque 3500.1D
XS Power D3100
Rockford P400X4
Lose wire from sub to the amp could be it.. Im thinking there a loose wire somewhere thats arching and causing a short burst of power making the sub go crazy.
2004 Grand Marquis
AA Mayhem 18
Crescendo 3500d
6.5's AQ Pro Audio
AQ Super Tweets
Image Dynamics 6x9
Soundqubed 125.4
MB Quart 80.4
144.2 db
GONZO
2013 Chrysler 300S
5.7 HEMI AWD
Corsa exhaust
Custom Tune
It could also be your electrical
From where are you seeing your voltage?
Have a Stinger volt meter that is calibrated... I just checked that again 10 minutes ago, at the amp
Audioque 3500.1D
XS Power D3100
Rockford P400X4
  • Who's Online   1 Member, 0 Anonymous, 1374 Guests (See full list)
