Ahmed Johnson Posted May 6, 2014 Report Share Posted May 6, 2014 Do you know where the ground is going? Grounds from front battery, 4 channel, and sub amp are all on the rear battery (XS Power D3100) and from there, have a metal bar running to the frame of the 3rd row seats mounting bracket it appears... Solid connection it seems... Yep, throws that out Link to comment Share on other sites More sharing options...
AASMDBASS Posted May 6, 2014 Author Report Share Posted May 6, 2014 well at least you found out why the amp was going into protect mode. Now for the tuning side of it go around 5hz lower than your box tuning for the subsonic and have your low pass at around 80hz if you want.. some ppl do more and some dont. You might need to build a new box also. Did you build this one to the subs specs or is it prefab? Definitely not prefab... Had it built to spec from sounds of tri state in Dover Delaware and it's very very similar to the one I had before, except the port is on drivers side now, and the inside of the box is fiberglassed Pioneer DEH 80PRS HU Ascendant Audio SMD 18" Audioque 3500.1D XS Power D3100 Rockford T1 components Rockford P400X4 Link to comment Share on other sites More sharing options...
AASMDBASS Posted May 6, 2014 Author Report Share Posted May 6, 2014 The frequency and which it sounded not so good was probably in the mid teens... Could it be that it's just way out of range compared to the box tuning? (32hz) Pioneer DEH 80PRS HU Ascendant Audio SMD 18" Audioque 3500.1D XS Power D3100 Rockford T1 components Rockford P400X4 Link to comment Share on other sites More sharing options...
AASMDBASS Posted May 6, 2014 Author Report Share Posted May 6, 2014 well at least you found out why the amp was going into protect mode. Now for the tuning side of it go around 5hz lower than your box tuning for the subsonic and have your low pass at around 80hz if you want.. some ppl do more and some dont. You might need to build a new box also. Did you build this one to the subs specs or is it prefab? Definitely not prefab... Had it built to spec from sounds of tri state in Dover Delaware and it's very very similar to the one I had before, except the port is on drivers side now, and the inside of the box is fiberglassed Also, how do I know where the filters and gains are set exactly to? The amp only has a minimum and maximum number for the filters/gains... Is it just a guessing game on if it's set correctly somewhere in the middle? Pioneer DEH 80PRS HU Ascendant Audio SMD 18" Audioque 3500.1D XS Power D3100 Rockford T1 components Rockford P400X4 Link to comment Share on other sites More sharing options...
Marquisboys Posted May 6, 2014 Report Share Posted May 6, 2014 Holy poo mid teens lol thats pretty darn low yeah it might just sound like the sub is floating and up and down and just hear the mechanics of the sub.. And for the filters you can do this...lets say my LPF filter on the amp is 20hz to 250hz you just add those up so its would be 270hz and divide by 2 which would be 135hz. so that right there is the mid point between the 20hz and 250hz on the amps LPF. so than you can take the 135hz and add the 20hz to it so its 155hz and now divide that by 2 which is 77.5hz. so exactly between the 20hz and the135hz is 77hz. Basically your finding the average of the numbers. 2004 Grand MarquisAA Mayhem 18Crescendo 3500d6.5's AQ Pro AudioAQ Super TweetsImage Dynamics 6x9Soundqubed 125.4MB Quart 80.4144.2 db GONZO 2013 Chrysler 300S Granite Crystal Metallic Exterior Inferno Red Interior 5.7 HEMI AWD LMI Air Hammer Intake Corsa exhaust Custom Tune Link to comment Share on other sites More sharing options...
AASMDBASS Posted May 6, 2014 Author Report Share Posted May 6, 2014 Here are the settings the audio shop has my gains and filters set to (bass boost is all the way down... Thought I'd mention that before someone thought it was up lol) Pioneer DEH 80PRS HU Ascendant Audio SMD 18" Audioque 3500.1D XS Power D3100 Rockford T1 components Rockford P400X4 Link to comment Share on other sites More sharing options...
Guest Posted May 6, 2014 Report Share Posted May 6, 2014 why is subsonic all the way down? Link to comment Share on other sites More sharing options...
AASMDBASS Posted May 6, 2014 Author Report Share Posted May 6, 2014 why is subsonic all the way down? subsonic is not all the way down... It's over half way Pioneer DEH 80PRS HU Ascendant Audio SMD 18" Audioque 3500.1D XS Power D3100 Rockford T1 components Rockford P400X4 Link to comment Share on other sites More sharing options...
AASMDBASS Posted May 6, 2014 Author Report Share Posted May 6, 2014 why is subsonic all the way down? subsonic is not all the way down... It's over half way I apologize... It IS all the way down Pioneer DEH 80PRS HU Ascendant Audio SMD 18" Audioque 3500.1D XS Power D3100 Rockford T1 components Rockford P400X4 Link to comment Share on other sites More sharing options...
Marquisboys Posted May 6, 2014 Report Share Posted May 6, 2014 Yeah subsonic all the way down is a no no 2004 Grand MarquisAA Mayhem 18Crescendo 3500d6.5's AQ Pro AudioAQ Super TweetsImage Dynamics 6x9Soundqubed 125.4MB Quart 80.4144.2 db GONZO 2013 Chrysler 300S Granite Crystal Metallic Exterior Inferno Red Interior 5.7 HEMI AWD LMI Air Hammer Intake Corsa exhaust Custom Tune Link to comment Share on other sites More sharing options...
