BassMunky Posted May 7, 2014 Report Posted May 7, 2014 Can you use shoe goo to fix the rubber surround around my 6.5 speaker germanium? It cracked down the side about 4-6 inches thanks Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
wccfan12 Posted May 7, 2014 Report Posted May 7, 2014 You can buy E6000 plumber's goop at dollars general for super cheap under 10 bucks. I used it to build my recones on my subs. It would def hold your surround together. I would let it set overnight for maximum strength but it only takes like an hour to set. THE ANTHRACITE DYC CRUISER -Fully dipped anthracite grey pt cruiser -4 skar vvx 12's (version 1) -Mechman 240 amp alt -Big three in Cadence 1/0 -1 deka intimidator g31 blacktop under the hood -1 C&D 140ah Batt & 1 C&D 55ah batt in the rear -Re audio/soundstream mids and highs -Hifonics Zues 600.4 -DC Audio 3.5k
BassMunky Posted May 7, 2014 Author Report Posted May 7, 2014 it a speaker and not a sub Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
