Box Help Please
I have 2 15" Big Shoks (same as Atomic ELE) that need reconed because of burnt leads that are burnt inside the cone. I plan on taking off the motors and putting them on either 12 or 15" Audioque baskets and using HDC3 recones to recone them. I drive a 2001 Toyota Camry and I'm trying to get the most dB's out as possible. I was thinking of doing a trunk(pony) wall with 12s but thought that 15s might be louder. Any help is appreciated.
All else being equal, more cone area = more DeeBeez. As long as you can fit 15"s, then that's what I'd do.
Builds:
I don't think there's enough space for 2 15s there but post your max dims, if by any chance can be done you will need to build inside.
x2
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
5.5 cubic feet box with 10 inch port @ 38hz
I live to hear the Bass drop!!!
Yah Max dimensions will be needed before you do anyting
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
Ok so using your 39 inches width, 17 inches height and 38 inches depth you will have roughly 12 cubes to mess around with. So on average that's enough for 2 15s (depending on your setup of course) So I would suggest either building a 4th order or just a ported box but firing the ports inside through the back inlet. I am not sure what your box specifications are for your subs (12s or 15s). And also what power will you be sending to the subs??
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
I think what I'm gonna do is recone my subs to 12s and seal them off from the trunk. I'll probably just give each sub about 3 cubic feet. After the recone they will take 2k each.
  • Who's Online   0 Members, 0 Anonymous, 4010 Guests (See full list)
