irnlve Posted May 10, 2014 Report Posted May 10, 2014 ok, i tried this a few times now with no prevalent luck. hopefully i can get some help here :-) ok, i have- - 1 Logic TXP3000d amp - 2 Rockford Fosgate 12" P3 dual 4 ohm voice coil subs - Vehicle is a 1998 s10 blazer 2 door - max available space is 20h x 18d x 35w - if possible i want the subs to fire upwards,and the port to fire rearward, if not that's ok - music listened to most is metal, but desired outcome is obviously max spl this is in a prefab ported box, but its a crappy box, its loud, but i kno it can be louder with the rite box, so if someone would please help, i will b very greatfull... thank you for the time..
cgrez33 Posted May 10, 2014 Report Posted May 10, 2014 People are probably still sleeping. Current Build: 1999 Tahoe #ComingSoon Previous Build(s): Crossfire Magnum 5k Pontiac G6 GT
Joe X Posted May 12, 2014 Report Posted May 12, 2014 What is a dd-1 ? It's an easy to use device that helps you setting your gains properly, it can save your subs from cooking due to amp clipping, if you don't/can't want to buy one, someone on this forum living near you who owns the DD-1 can help you setting your gains with the device. So that you know what is it here's a link: http://www.wccaraudio.com/front-page-categories/most-popular-products/smd-distortion-detector-dd-1.html I just want to forward you some infos before you get into building your box.
irnlve Posted May 12, 2014 Author Report Posted May 12, 2014 Ya I have a friend n town here that competes and goes to world, I believe he has one..
Joe X Posted May 13, 2014 Report Posted May 13, 2014 So this is just a sample design for a dual tuning box, I have set a low tuning of 34Hz with one pipe plugged or 40Hz with all pipes open, optionally you can build a removable port for the box so that you can tune to other frequencies. TO NOTE, this is not a spl box since those are setup with a termlab and the parameters of the box are changed at test time. Your amp subsonic filter should be set no more than 5 Hz below tuning during the tests or thermal/mechanical failure of subs may occur. Also if you don't have proper power and gains properly set thermal/mechanical failure or amp damage can occur so be advised. Minimum port clearance = 4" Removable port module version:
irnlve Posted May 13, 2014 Author Report Posted May 13, 2014 wow, this is remarkable! but i think i understand what your getting at, thank you SOOOOO much.. im going to get started on it this week and will post some pics asap!
