torres box calculator problems
i have come upon a problem and im wondering if the coding for torres box calculator has been updated or something, there is differences between box specs..im using torres 2010 and 2011 v 1.1 , which version is correct?? here is some screenshots of the differences
http://imgur.com/1NMLBjI there is version 2010
http://imgur.com/D1O3Sse and there is version 2011 v 1.1
There's two versions so of course it has been updated, both versions are slightly off, you can review all the issues that have been found on Torres thread, to summarize I can tell you that there are two major flaws:
1) port displacement is miscalculated, it results normally in 0-2 Hz off the correct calculations, exceptionally 3 Hz off.
2) tuning is miscalculated when using multiple round ports, with a single one it works just fine.
A number of other small glitches have been found that are not really important IMO. Some users in specific machines have experienced major calculation issues but I know of no more that 5 people to my knowledge have experienced this (I was one of them in an older machine but running the software in a VM corrected the problem).
ok kool, i have a couple questions for you then
1. would you go with the calculations for the threatcon2 15" that i came up with using 2011 v 1.1 ?
2. would you be able to come up with accurate box specs for the sub?, i'd like to keep around 3.75 cu ft net, 33-35 hz tuning and 16-18 sq in port area per foot.
im gonna go 3 common slot port
  • Who's Online   0 Members, 0 Anonymous, 3139 Guests (See full list)
