2012 honda civic si 2 12 inch sundown 4th order build
hey everyone i have a little problem i will be designing a 4th order box for 2 12 inch sundown zv4
heres my setup
2 12 inch sundown zv4s
1 saz4500
2 xs 3100 batterys
1 240 amp alternator
my problem is im looking to setup this build at .5 ohm it will be around 10k watts the box design is my problem since its a small car i know im loosing my trunk either way but is there any options other then a 4th order
the box will be only in trunk i am not extending it into my back seat
You could do a 5ft^ ported enclosure forward facing port in middle and trunk sealed off..or you could do a sealed box..or you could do a 4th order or 6th order..check it out on you tube..ive seen a few people have two zv4 12s in newer civic coupe and 4dr. But they all have boxes ported firing forward.. honestly I think if you did a 4th order it would be so small that you would probably have to give each sub 2k watts to even get them moving the way it should..remember the higher the wattage the smaller the enclosure you should do ..and the lower the wattage the bigger the enclosure you should do..this really on goes for watts higher or lower than rated rms..but those zv4s can handle anything you throw at them..and if they dont well sundown can recone em for you and make them even better than before
You need trunk space to get groceries and shit...bitches love groceries
There amps can handle up to 13k and there subs you can double the wattage
Yeah I've got a feeling you don't know what you are getting into
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
