Chris Braun Posted May 12, 2014 Report Posted May 12, 2014 Hi, I was just wondering about 4 channel amps and haven't been able to find an answer to this question. Can you run lets say ch 1 and 2 @ 2ohms for fronts (more power) and ch 3/4 @ 4ohms for the rears and vice versa (guessing not). You can bridge ch's 3/4 of a 4 channel amp and not 1/2, but just want an educated answer. Thanks and appreciate it!
mmets Posted May 12, 2014 Report Posted May 12, 2014 I have a DC 175.4 running my comps. Channel one and two are at 2 ohm. Three and four are at a 4 ohm load. I have not had any issues with running the amp this way what so ever. As long as the amp is 2 ohm stable you should not have any problems. Edit: cant spell http://www.stevemeadedesigns.com/board/topic/177477-slowboring-07-trailblazer-build/Pioneer DEH-80PRSPRV 8MR400-NDY (eight) PRV TW350Ti (6)Sky High 1/0 OFC, 12 gauge and 8 gaugeTM Metalworkz battery terminals 120 sqft HushmatXS Power D3100 (6)Singer 350 Amp Alt Singer 320 (2)American Bass SQL3200 JL Audio JX360/4 Crossfire XS 8K (2) DC Audio XL 15s (6)
GSanders17 Posted May 12, 2014 Report Posted May 12, 2014 Not sure what 4ch you are using but in my experience you can bridge channels 1/2 together and 3/4. You could also run the fronts at 4 and rear at 2 or vice versa. If you bridge say the rear channels together just don't run an impedance less than 4 ohms.
Chris Braun Posted May 30, 2014 Author Report Posted May 30, 2014 Thx for the replies. Kinda figured it should be ok. Won't be bridging it, this is about the 2 ohm JBL speakers I bought for my lil bro, and just general knowledge. Didn't buy an amp yet and just had the idea that the front and rear ch's on a 4 ch amp were separate but wanted to make sure. Possibly will be buying 4 ohm for the back (cheaper ones) later so was just wondering.
