94 Ford Beast-350 OBS CCLB - Motor is done, need to sell, questions-please help
So after all this painting parts, and prep work to make this thing look good, it's finally time to start putting something back together. This is the new power steering pump, the painted pulley, painted bracket, and the painted belt tensioner.
11082248_709139675861832_483433580619845
First I bolted up the new Power Steering pump.
1498854_709139682528498_8227307178381641
Just a side view with all the plugs still installed. I will leave these in until it's time to connect the hoses and fill it up.
11080860_709139685861831_855883627871114
Put a little assembly lube on the shaft as well as the pulley. This should help with pressing it back on.
10845698_709139722528494_541152033887887
This is the little "tool" that helps to get the pulley on. It's simply a bolt, with a square nut on it, and a washer. I had an issue with this. This came with the kit, and while it wasn't completely the tools fault, it was very cheaply made. Part of the issue was the paint that got inside the hole of the pulley. It made it small enough to cause an issue, and combined with the cheap hardware of the tool, I ended up stripping the nut and bolt. I had to improvise with on e of the ARP bolts. Lesson learned.
11134013_709139725861827_811746778146429
11025254_709139735861826_331122284880025
11020751_709139762528490_898352855622468
I managed to get it about this far and then started having issues. I ended up pulling it off, and cleaning it out with a wire brush. Then tried again with different hardware.
11075283_709139765861823_150347341079433
But I finally got it on, and then bolted the belt tensioner on as well. One piece of this complicated puzzle is put together.
10845803_709139785861821_443479116109636
Now that at least one piece is put together, I'd call this the put back together stage. Things are about to get exciting.
Let's strip the headers and see what they look like!
1899558_709139815861818_5995580020585791
11112905_709139832528483_511935896076576
10845659_709139849195148_489241104772815
Time to prep the block. I wiped everything down and go tout the tap to clean out the holes. A little 3in1 oil and some patience and got each hole cleaned out.
11082264_709139865861813_898856635137320
11080289_709139882528478_402495863422892
10887117_709139899195143_759291961985822
Now, to do this job and reuse the original bolts would just be a crime. So I picked up some ARP bolts to get this job done right.
10383765_709139925861807_187214968870155
Header is sitting here ready to go home. Time to climb in and get er done. Damn this thing has some weight to it!
11051847_709139935861806_843328371986878
Each bolt got torqued down per specs and in order out of the book. Did it in 3 stages, 70 ft lbs, 110 ft lbs, and 140 ft lbs.
11113389_709139949195138_117191676636248
Repeated the process for the other side. She's starting to look like a motor again!
11080549_709139972528469_434444884969416
Next was the valley. It needed to be cleaned up still. Sprayed it down with some WD-40 after plugging the holes to the cam. Letting that soak a minute.
10997783_709139975861802_905257170721191
Using a couple of wire brushes, and some rags to clean it off, this is how it ended up. Pretty good in my book.
11053660_709139992528467_834055510081335
Time for the intake manifold. New Gaskets to be used too.
11062747_709140012528465_361529753180760
More ARP love as well.
1556232_709140032528463_9060093455672410
Got the tape stripped off the intake and ready to go in.
10848702_709140039195129_391926955549319
A little black RTV for the ends.
11082371_709140049195128_545742486265094
11113034_709140092528457_844698759811036
11082263_709140095861790_124828059779184
11075303_709140112528455_183721562299954
11021532_709140162528450_408903960430721
I dont know how you take so many pictures.... LOL
Also I told you that the rust in the cylinder wouldnt hurt you ;)
Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born.
My penis is bigger than your penis
I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
After that was done, I figured I better get the push rods in before I couldn't see where they go. I'm sure I could've felt them out but I didn't want to put for that much work when it's all exposed now.
176619_709140169195116_30054814523566991
A little assembly lube to go on the rods.
11111919_709140165861783_422307489490840
11053627_709140202528446_982467079949016
Driver side done.
11087797_709140222528444_800205670026054
Passenger side rods in, and intake in place. Not bolted on yet though.
11082407_709140215861778_492700017333081
ARP bolts, let's get her tightened down. Again per spec, and in order by the book. 2 stages this time. 15 ft lbs, and then 45 ft lbs.
11034373_709140235861776_155873085291048
And this is what she looks like now. Everything is tightened down. I did notice however, that the top of the heads above the intake manifold are still raw metal. I may have to spray those black. I didn't realize that they were going to show. Probably just the ocd in me, but it bugs me.
11088448_709140282528438_783711471799610
So that's where I'm at now. I have the smog pump bracket to put back together. I also realized I forgot to paint the throttle body as well. That will have to get done. It'll stick out like a sore thumb otherwise. But I'm making progress.
I also thought about an issue I did. I was cleaning the pistons and cylinders etc, and turned the crank shaft to expose the cylinders, but I forgot to mark the cam and crank before I did it. So now I'll have to find TDC, and the compression stroke before I put it all back together. SO I think the timing chain etc will be next so I can get that taken care of.
Also still have the sensors etc to put on the intake, but I'll do that soon too. Lot's to do still, alot of little things especially, but it's coming along. I'll work on it more tomorrow night.
A lot of it I do for my own good so if I get confused I can refer back to them, but I do it for others too. I think I said in here somewhere, but I can't remember and don't wanna look for it, when I was researching this project, I couldn't find anything that was very descriptive on how to tear down and put back etc. SO I thought if I'm going to go through the work, I might as well document it good so someone else can benefit from it in the future if needed.
Yes and I believed you. It came off relatively easily. Thanks.
To find compression just turn crank over with your finger on #1 cylinder until compression will push you finger off. Then stick a small screw driver in and watch it move with the pistion.
Never mind you have the timing chain off LOL
  • Who's Online   1 Member, 0 Anonymous, 1137 Guests (See full list)
