94 Ford Beast-350 OBS CCLB - Motor is done, need to sell, questions-please help
Now back to this thing.
10506822_587152128060588_512725388447179
Remove the bolt.
10540961_587152144727253_141859353604082
Get out your pulley puller.
10483070_587152164727251_803777755814246
10541425_587152181393916_677857084687703
10560275_587152208060580_357960694757385
10549189_587152224727245_758692711608824
10557635_587152231393911_803427303017627
Time to remove the anti balance. This was a pita. That little piece needs to come out of the shaft. Found out how to do it. I did it this way. Grabbed an old screwdriver. Ground off the edges, then used a hammer.
10521323_587152271393907_677089652237351
10582765_587152304727237_453375635841048
10604030_587152324727235_610574620350146
10499364_587152354727232_311217297757364
10382253_587152378060563_560705490793618
Tap down and lift up. It's not square, its a half moon shape.
10498105_587152388060562_897482688559351
10547274_587152408060560_138511977985558
10619973_587152438060557_201072662647928
10531390_587152451393889_719065017976899
Then slide it off.
10273102_587152464727221_272197105493180
There is a groove in it. This is on the bottom of the crank shaft. ALSO, DO NOT LOOSE THIS PART. THESE ARE HARD TO FIND, AND THEY'RE EXPENSIVE IF YOU DO FIND ONE!!!
1926248_587152488060552_6124139732967699
10548167_587152504727217_139779917863365
Here's the piece that the notch slide over.
10506677_587152524727215_537063489322718
Let's remove the timing cover. This is an absolute mess under here.
Bolts
10557691_587152554727212_181731391740442
more bolts
10580968_587152564727211_124576996337173
Oil pan bolts up front.
10620333_587152571393877_871108392803102
10582807_587152601393874_720844678166431
Need to see if I can clean this up, or if I just buy a new one. We'll see.
1531874_587152608060540_6515028991878862
Timing gears and chain. I think this is where my oil leak is coming from. I don't think it was the pan at all now. I think it was the side of the timing cover.
10498379_587152618060539_431468237059488
This notch and the lower gear notch have to line up. Let's move the crank and line em up.
10486020_587152651393869_656751476219073
10535586_587152658060535_361709823656381
1493503_587152678060533_4181491046349810
10499416_587152694727198_600445584813261
Boom!
10530534_587152718060529_789907845725143
10515260_587152724727195_496373165971950
Remove the bolts, and then work it off. I used a pry bar, LIGHTLY, and then just worked the top and bottom gently until they slid right off.
10498532_587152744727193_687351072872745
10517932_587152764727191_907960172449995
That's it. That's where I left off. I need to still pull the fuel rails, injectors, and intake manifold. Then I can either pull the heads, or pull the whole motor and work on it outside of the truck. I may do that so I can replace the oil pump and the oil pan gasket. I have one so why not.
I'm trying to figure out how to get the whole front frame off. I'm pretty sure i see how to do it, but nothing confirmed yet. I'll pull the bumper too.
That's it for now, I'll be back on it next week. Thanks for watching.
Damn now i know what im in for with my 302 in my explorer lol different motor i know bht same concept lol. Cant wait to see what you do
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
Man that was very thorough lol! But best way to do it! For when it come time for reinstalling.
Looking forward to seeing this back together and starting the real build lol! It's looking good so far buddy!
Funny how the people who have a louder system than you will usually give you a compliment about your setup because they know how much blood, sweat, time, and money you put into it. The people who criticize or try and one up you....have a p.o.s to no system at all and will tell you all about this "other" guys system! Saddley I'm sure if I meet this "other" guy...he will probably tell me he thinks your just as annoying as I think you are!
I'm not compensating, just proud of fabricating!
My build log: 10k center console with 4 DC Audio XL 10's powered by 2 DC Audio 5.0k amps 5 xs batteries and dual DC Power 300xps alts
http://www.stevemeadedesigns.com/board/topic/169404-goodvibez-04-dmax-10k-center-console-w4-xl-10s-custom-5ksit-plays/page-19
Seeing all of the steps so far on the engine teardown makes me not want to touch one lol. too many plugs and parts that, knowing me, I might forget to put back, forget where they go, or just flat out lose them lol
2016 Ford Focus SE
No build log yet
DC Audio 1.2K
2x DC Audio Level 2 10"
  • 1 month later...
WOOOOOOOOOOOOOOOOOO it's been a minute since I've been on here. Life is BUUUUSSSSSYYYYYYYYYYYYYYYY! Ok so I had to go back and see where I left off lol!
So here's where I'm at. I did finally get the driver side head off with minimal issues. It looks like I had a head gasket blow out into the valley at the intake side. Where it was at, it was sealed up so I wouldn't have been able to see it from the top. So that makes me feel better. I have the gaskets and stuff already because that's what we originally thought it was.
I checked over the rods, rockers, valves, pistons, and really everything. Everything really doesn't look bad at all. I think what originally caused this, and I wish I could find the damn receipt cause I'd act on it, was I went to Autozone to find a spark plug when I was doing the headers. #7 didn't look good. Not terrible, but for being a fairly new plug it wasn't up to par for me. SO I went get a new one and the guy at Autozone gave me the wrong one. I was told it was burning too hot and that was causing issues. I don't know how accurate that is, but I can say that what it looks like after I pulled seems like it would be that way. It's black under the valves on that piston only. The rest of the valves and pistons look consistent with each other. Where the gasket blew out is in between both #6 and #7 but closer to the #7 side. So that would explain the lack of compression in #6 and way worse in #7.
So, now I need to pull the passenger side head and take a look at it. If I'm going to do the driver side gasket I might as well do the other side since it's all torn apart.
Another thing I found was that it doesn't appear to be the oil pan that is leaking as I thought. It appears that the timing cover gasket failed as well and that's where the oil leak was coming from. SO that's another good thing because now at this point I don't "HAVE" to pull the motor.
Here's where I'm at. I'm going to pull the passenger side head. Then get them both cleaned up and I'll check em for warping. Hopefully I can go ahead and put them back on with out having to spend too much money. My plan is to get it all cleaned up, put it back together, and then clean up the motor.
The reason I'm not going the extra miles on it, is that we're going to go ahead and sell it. I picked up my new to me 06 F250 CCSB Lariat with the 6.0 PS. It's black with grey leather interior. Very good shape as my brother and sister in law really took care of it. Just over 100K but it's been well maintained and runs beautifully! So because my time sucks, I'm going to go ahead and sell the beast, and the money I get from her will go into this one. Nothing major, small lift or just a level kit, rear bags, 20" wheels and tires, possibly a chip or programmer for when I tow etc. Tint all windows, and I am going to put a shell on it as well. I originally wasn't going to, but the more I look at it the less I see the ability to do anything sub wise inside. Don't want to cut it, so I'm thinking some how doing an enclosure with 2 or 4 12's and going into the rear window. But I'll plan it all out another time. I can't do anything till I get this one back together.
So there you have it, everyone is up to date. I have pics to post of my work on the beast. I'll get those up tonight if I can.
Let me know what you all think! I'm curious to hear it.
