94 Ford Beast-350 OBS CCLB - Motor is done, need to sell, questions-please help
The seal that needs to go in the timing chain cover.
11722536_761739143935218_140365549012184
Piece of cake. It's home!
11411758_761739160601883_334725423680208
The next morning I got a delivery. More parts from Summit Racing. They've saved my ass on this build. Great service, good prices, super fast shipping. Course it helps I'm only about 3 hours from their Nevada facility, but whatever.
11698953_761739193935213_308890194968248
11411832_761739203935212_129496739399827
Ford Racing Performance Spark Plug Wires
11722674_761739217268544_504867681969551
Fram Transmission Filter Kit
11741166_761739240601875_322658909592036
New lighter fan
11754607_761739250601874_757501432579655
And a new radiator, since the other one was in pretty rough shape.
11143594_761739273935205_309790046160737
Back to the timing cover.
Back to the timing cover. Since it's all ready to go on, I started getting the gaskets ready to go on. Super Blue Silicone will do that nicely.
11731651_761739293935203_411212335406048
11250151_761739307268535_608520945526502
Here it is in place. I had to clean some of the silicone up. Didn't want any where it shouldn't be.
11754393_761739330601866_653196671248705
Next I added some to the outside of the gasket to go between the timing cover and the gasket.
11722418_761739343935198_160188627377386
Also added some black silicone for the oil pan and gasket.
11699069_761739357268530_677433922134966
ARP Bolts for the timing cover and water pump. Let me just say this. When I bought this kit I was so excited about it. All new bolts, and all black, and it would be nice and easy and make such a clean look. I was wrong. Most of these are not the right size. Most are too short. So at the end of the day, I ended up using most of the bolts I had for the timing cover and water pump. I wanted to get new stuff, but I just couldn't locate any hardware for it. I'll see what's out there some other time. About $250-300 I could've saved myself I'm sure.
11017239_761739380601861_513013653659943
Prepping the timing cover. Black silicone on the bottom, blue on the back.
11161688_761739387268527_330731800286700
After alot of fighting it, and probably removing it and redoing it about 4 times, it's finally on, and tight. I did manage to use some of the ARP bolts, but there are some originals on there as well.
11705403_761739403935192_867512929690990
But i had to keep going after all that frustration. Time for the water pump. More blue silicone.
11109494_761739430601856_216052509491998
Brand new backing plate.
11728767_761739457268520_691859342338498
Brand new water pump ready to go on. Painted ford blue.
11713767_761739460601853_908085477388400
gasket on, and more silicone ready for the pump.
11012128_761739473935185_797100551127064
And with the original bolts, it's on. Everything is torqued down to spec, and all looks good. Of course I have no fluid to put through it yet, so I'll just have to wait, and hope, and see that there's no leaks. Cause that would suck.
11699026_761739767268489_577698439527682
11412057_761739770601822_267649762679056
Those bolts will be addressed btw. No way I'm leaving those without color.
Lets get back to the valve covers.
Rubber washers from home depot for the valve covers.
11722251_761739773935155_605747021904209
Hand tight for now. They need I think 10lbs of torque according to the book.
11731576_761739823935150_909946510603282
11717468_761739827268483_463854031328126
After torquing them down, the washers roll up on the ends. Not a big fan of this, it looks bad. I'll probably address this later on.
11059205_761739830601816_681720959240300
11741257_761739883935144_530098715835816
Close up of what it does.
11703296_761739893935143_806227882053844
Got some hose to go from the water pump to the intake, and some new hose clamps.
11411924_761739913935141_716244676833949
All that hose, and I only needed this much. But, they only sold it by the foot.
11696398_761739993935133_164179903811625
For this little connection here. Sheesh.
11696357_761740010601798_549037487772493
Then I got the clamps on. After I got the clamps on I noticed a mistake I'd made. So in the interest of transparency and showing everyone that I'm just learning how to do this as I go, I'll let you in on the mistake. I didn't take pictures of it. However, inside that threaded hole on the left side of the hose I just installed, goes a little neck for another hose. Well the hose connection on that neck, makes it an "L" shape. Well it hits the timing cover. So instead of taking the timing cover off, and going through that BS all over again, I took the intake off and put it on that way. Easy fix, but man that could've been bad. One step forward, two steps back.
11055253_761740003935132_730318506328746
Getting ready to get the external balancer on now that the timing cover, seal, etc are on now.
11698757_761740040601795_594519771395932
Applied a thin layer of lube and it slide on for the most part. I ended up having to clean the inside of the balancer a little bit. But it went on pretty easily.
11713947_761740057268460_466189354572045
Got the insert in to keep it in place. There are no bolts that hold this on, or spring clips, or anything like that. The crank bolt which holds the harmonic balancer on is what holds this in place along with this insert.
11709942_761740070601792_271542804044084
Brand new Harmonic Balancer.
11241938_761740090601790_630574525208836
11731617_761740100601789_603273818545367
New key insert. The other one was from the old set, so I removed it and put this one in.
11741111_761740110601788_659763520902534
LUUUUBBBBEEEEE on the shaft!!!
11174484_761740130601786_142238736221642
Got the new balancer on, and bolted down. Bolt torqued to spec.
11411875_761740443935088_327371636739219
Next it was time for the pulley. Not new, but it got a cleaning and some paint. ARP Bolts again.
11212193_761740450601754_380695294184474
11754393_761740463935086_500408596456815
Obviously wasn't thinking about this one. Missed painting the inside on it. Ooops. I'll fix that.
11267730_761740477268418_525460267390874
Fixed
11221666_761740510601748_633374353185576
Ok, lets work on that throttle body next. 11221433_761740143935118_187148830669441
11754826_761740157268450_914973193863778
11705656_761740177268448_327547821829590
Ports are filthy.
11700774_761740190601780_258428932652130
Flaps are filthy. Removing those two screw on each flap will remove them.
11707856_761740207268445_668080025046846
Gasket has some oil to the outside of it in one corner. Interesting. Not sure what that means.
11411984_761740230601776_212654992838068
Flaps removed, now it needs to be cleaned. Let's see, where's my wife's toothbrush at?!
11713771_761740240601775_198690652495498
11411924_761740257268440_552492792999259
Flaps will sit in the parts washer for a nice bath too.
11728949_761740283935104_478936991615024
11713822_761740293935103_331291320938986
Much better. My wife has a nice toothbrush. Well, had a nice toothbrush.....hehehehe
11754355_761740313935101_152082690153265
Clean flaps back in.
11411758_761740347268431_734951932573695
Time for some painting fun with Scooter!
11754481_761740377268428_286240449310666
11013313_761740380601761_502152362997613
11700845_761740390601760_768005392579793
Check out my kickstand. Evidence. I had to replace my wife's toothbrush lol.
11741168_761740427268423_466749407101388
Thermostat neck ford blue. This color just pops off the black. Really happy with it.
11741111_761740520601747_697077753619993
Timing point. Needed some help bad. She's black again. I thought about painting it another color but I don't think it would work, I don't know enough to know and I don't want to have to do it over again.
11729007_761740540601745_404332637859887
This is a metallic grey. The pictures don't do it justice, because it has a real nice metallic look.
11722303_761740557268410_323357771948743
11754469_761740573935075_336264941624691
11741233_761740590601740_110639480015567
11717376_761740607268405_864406392818943
Got the vacuum trees on, and the new sensors on.
11754500_761740637268402_514460725208649
Nice picture of the front, well, just because I was happy with it so far and felt like it needed a picture to be taken. See the neck on the left side there on the intake, above the water pump. Remember that was the piece I had to put on, the mistake. LOL.
11722258_761740653935067_462023286168020
Time to put those beautiful injectors on and the fuel rail. I'm pretty happy with how this turned out.
11713835_761740687268397_194641780363853
The newly rebuilt injectors ready to be installed.
11703448_761740733935059_375643261067812
Injectors, and fuel rail on. Bolted down with ARP bolts.
11221433_761740767268389_411693256363795
Fuel regulator.
11227776_761740793935053_900028400091335
it goes here.
11109494_761740830601716_645924080394484
Like this!
11411819_761740843935048_281872070727179
Thermostat and neck. ARP bolts to hold them down, and some blue silicone to seal it up.
11059205_761740857268380_717662805565287
Done.
11741283_761740900601709_261831392514495
Let's put the Throttle body etc back together.
11722554_761740940601705_528473575372462
As you can see, ARP Bolts, got a new Idle air control valve, and the throttle position sensor is fairly new as well.
11754724_761740943935038_415034735566084
11717444_761740953935037_670810942223954
Idle air control valve, gasket, and throttle position sensor.
11698860_761740997268366_628709669942769
11722536_761741007268365_295338312498518
Time to go home!
11010518_761741073935025_469766170358819
ARP Bolts lubed up and ready for duty.
11741277_761741117268354_725136104370859
New gasket.
11222260_761741123935020_888926989834165
And we have touchdown!!
11069900_761741133935019_386199980151546
Overhead view. Looks like a motor finally!
11722514_761741167268349_592057111868882
So that's where I'm at today. This weekend hopefully I can get the surroundings put on it, and then do the vacuum lines and get close to starting her up. That might be a stretch though. STill lots of little details to deal with.
Thanks for watching, and hopefully I'll have much more this weekend. Love to hear any comments or suggestions or if you have any questions ask away. Thanks!
Awesome work man.
She looks great.
