exc500 Posted May 14, 2014 Report Posted May 14, 2014 Just got a rf 10001 bd and its doa. Opened it up and all caps are in good condition and overall board isn't in bad shape but at least 3 or more fets are blown and the little circuit's they attach to. I know this is just a starting point on the obvious repair which ill be sending to a decent repair shop to do. The amp does nothing when power is applied to it so its not dead shorted not to say the traces couldn't be burnt totally into. Is this a amp worth fixing its in better than average shape for its age it is stamped on the circuit board made in usa its the bigger grey model not the new stuff. I really dont want to see believe its junk. Any suggestions? Thanks!
Skax Posted May 14, 2014 Report Posted May 14, 2014 Just got a rf 10001 bd and its doa. Opened it up and all caps are in good condition and overall board isn't in bad shape but at least 3 or more fets are blown and the little circuit's they attach to. I know this is just a starting point on the obvious repair which ill be sending to a decent repair shop to do. The amp does nothing when power is applied to it so its not dead shorted not to say the traces couldn't be burnt totally into. Is this a amp worth fixing its in better than average shape for its age it is stamped on the circuit board made in usa its the bigger grey model not the new stuff. I really dont want to see believe its junk. Any suggestions? Thanks! I don't think anyone but Rockford deals with the Rockford amps and repair is 321$ so imo no 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
Kyblack76 Posted May 14, 2014 Report Posted May 14, 2014 Calling rf tech support for a RMA number is best bet. They "flat rate" all amp repairs. New board, and all. 1800-669-9899 Forrest usually picks up... if your lucky, youll get Amy. If its worth it,. well thats up to you. Good luck. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
exc500 Posted May 14, 2014 Author Report Posted May 14, 2014 Called fosgate repair and they refer me to Freeman car audio for repair. He said probably between $100 &/200 to fix it. Its the older grey series that's stamped made in usa on the board. Its been a great amp and hate to see it junked so I dont think I can get as good an amp for what it will cost to repair this one seeing as It has worked for years perfectly. Its more than paid for its self especially seeing as I got it for around less than $100 years ago . I work at a pawn shop and every now and then I run across some really nice equipment. Id love to see it back pounding away!!
Kyblack76 Posted May 15, 2014 Report Posted May 15, 2014 Well, your call bro. It would be something cool to do for the audio people that like to see the old gear still IN AND RUNNING.. Also, RF repairs, are basically a total RECONDITION. You dont get a dab of solder, or a replaced fet, you normally get a fully restored board. You can get it repaird for a 10th of the original old day price. Choose wisely. Good luck. If you choose to put money into it, will you please post pics. Thanks.. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
jdshott Posted May 15, 2014 Report Posted May 15, 2014 I agree with KyLar96 Its your choice. but imo if it cost less than a new amp then roll with it. you already know the quality ... No 1 But me paid for this stuff and NO FREEBIES so no brand names (No Free Advertisement ) A SQ head unit 6 5.25 2 X 6x9s 7804 P400.4 4001D 1 34s (Maybe time to change brand) 4 X 15" s !/0 @ 2/0 OFC Wiring :morepower1: :morepower1: ill say it like i always say it. F##K the DD-1. I don't care if you or anyone buys one. (well i do, but that isn't my point) Get an O-scope in the very minimum and learn how to use it or you are just guessing your settings like every other noob. once you master the O-scope then step up to a DD-1 or even better a DD-1 Plus.
exc500 Posted May 15, 2014 Author Report Posted May 15, 2014 I called the number that I was given for Rockford fosgate and they told me that they dont do repairs on that model amp and refers me to Freeman car audio. That was straight from Rockford fosgate. Which really surprised me I know its older but not like its a old school power 1000 mosfet. Believe me id much rather have it done at Rockford fosgate. If I should call another number let me know.thanks
Kyblack76 Posted May 15, 2014 Report Posted May 15, 2014 Dude, If they refered you to them, then, they are the NEXT best thing. Its probably a dude that use to WORK at RF tech. Rf cant support every single product they put out for ever, under one roof. Theyd go broke paying people sitting around waiting for a 35 year old amp to come in. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
exc500 Posted May 15, 2014 Author Report Posted May 15, 2014 Dude that's kinda what I figured. But the other responses sounded like they thought I should be sending it to rf. All I was asking was if maby there was another # I should try. Im getting it repaired for the estimate I was given its well worth getting fixed. Im 43 ive been installing and or involved in car audio since I was 15. So I enjoy the old school amps as much as anyone. Thanks for the input and unless anyone knows someone at rf that would do a factory repair on this amp then its probably going to Freeman's.
exc500 Posted May 15, 2014 Author Report Posted May 15, 2014 And KyLar96 thanks for your help. I do appreciate it. I guess I got the guy not the chick to answer.either way I appreciate your help.
