Edgare50 Posted May 15, 2014 Report Posted May 15, 2014 Been looking at fat mat and for the price i guess you can say you can't go wrong with that i don't have much rattle coming from my vehicle except for the bumper, assuming its all coming from the spare donut!! lol my stock wing flexes, trunk moves a whole lot, but not much noise (rattle) would also like to gain at least a db or from the deadener, but as usual as a college student, don't have much to lay $ would appreciate some advice or tips on what i should be doing thanks! cheers!! 2 Soundqubed SQ1-2200D 1 Soundqubed Q4-120 4 American Bass VFL 65MR 2 American Bass HD 15's 2 American Bass MX-250T 2 American Bass MX-252T 4 XS Power XP950 Tons of Sky High Car Audio Cable "Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science..."
alaskanzx5 Posted May 15, 2014 Report Posted May 15, 2014 I only have experience with dynamat extreme but figured I can give advice. well placed deadener can go further then co wrong everything when it come to keeping cost down rubber washer or simply putting stuff between things that rattle up against each other works. expending foam would add weight to the trunk lid and stiffen up the panels some. when you do it find one of the biggest rattles place some deadener then test and repeat until a you get most of the major rattles then start on the small rattles. second skin bstock is fairly cheap and people seem to get great results for it. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
jdshott Posted May 15, 2014 Report Posted May 15, 2014 The fat mat looks ok . But check around, second skin and sound qubed are proven choices . as Alaskanzx5 said placement makes a world of difference,, No 1 But me paid for this stuff and NO FREEBIES so no brand names (No Free Advertisement ) A SQ head unit 6 5.25 2 X 6x9s 7804 P400.4 4001D 1 34s (Maybe time to change brand) 4 X 15" s !/0 @ 2/0 OFC Wiring :morepower1: :morepower1: ill say it like i always say it. F##K the DD-1. I don't care if you or anyone buys one. (well i do, but that isn't my point) Get an O-scope in the very minimum and learn how to use it or you are just guessing your settings like every other noob. once you master the O-scope then step up to a DD-1 or even better a DD-1 Plus.
Edgare50 Posted May 15, 2014 Author Report Posted May 15, 2014 I only have experience with dynamat extreme but figured I can give advice. well placed deadener can go further then co wrong everything when it come to keeping cost down rubber washer or simply putting stuff between things that rattle up against each other works. expending foam would add weight to the trunk lid and stiffen up the panels some. when you do it find one of the biggest rattles place some deadener then test and repeat until a you get most of the major rattles then start on the small rattles. second skin bstock is fairly cheap and people seem to get great results for it. The fat mat looks ok . But check around, second skin and sound qubed are proven choices . as Alaskanzx5 said placement makes a world of difference,, yeah, just thought fat mat was fairly cheap, and like i said i don't really get too much rattle, for know only running less than half the power all trunk, so im assuming once i get everything settled and purchase my amp ill probably be getting more ill look into second skin, seen some reviews on youtube, so ill see whats good thanks guys 2 Soundqubed SQ1-2200D 1 Soundqubed Q4-120 4 American Bass VFL 65MR 2 American Bass HD 15's 2 American Bass MX-250T 2 American Bass MX-252T 4 XS Power XP950 Tons of Sky High Car Audio Cable "Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science..."
alaskanzx5 Posted May 15, 2014 Report Posted May 15, 2014 Look at there bstock options, its the same stuff just doesn't meet there quality standards for them to sell it at the same price. some of the things on why they sell it for less are, no uniform thickness, gaps/missing spots of foil, and maybe even little things like small wrinkles in the foil or deadener itself. The product is still made from the same materials just under what they set the quality they want in their product. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
jarredondo1999 Posted May 15, 2014 Report Posted May 15, 2014 I've used this and it works pretty good. http://www.raamaudio.com/
jarrius Posted May 15, 2014 Report Posted May 15, 2014 I used soundqubed's q-mat cheaper and worked great on my trunk. It usto rattle like a bitch. But after deading just my lid I did not gain any db's 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
Edgare50 Posted May 15, 2014 Author Report Posted May 15, 2014 I used soundqubed's q-mat cheaper and worked great on my trunk. It usto rattle like a bitch. But after deading just my lid I did not gain any db's yeah, cause even if i don't gain any db, at least i won't get much rattle all in all, looking for something decent so not sure if i should get FatMat or Second Skin 2 Soundqubed SQ1-2200D 1 Soundqubed Q4-120 4 American Bass VFL 65MR 2 American Bass HD 15's 2 American Bass MX-250T 2 American Bass MX-252T 4 XS Power XP950 Tons of Sky High Car Audio Cable "Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science..."
Tecomah Posted May 15, 2014 Report Posted May 15, 2014 Second skin all day. 750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.^ DON'T BE A DICK LIKE THIS GUY Team Subsonic Lows
PolishThunder Posted May 15, 2014 Report Posted May 15, 2014 I have no experience with it but I have heard that q-mat is really good for the price, only problem is it sells out fast sometimes
