Roger Peru Posted May 16, 2014 Report Share Posted May 16, 2014 Hi guys, below I have designed a box with all external dimensions using 3/4 wood. I want to tune this to around 32 hertz, any one kind enough to help me out with the port dimensions. The height is already 12.5" but I need to determine the width and the length of the two pieces in red in order to get the right port length. Height-14" width-35" Depth-24" BTW this is for two rockford T1 12" Link to comment Share on other sites More sharing options...
Joe X Posted May 16, 2014 Report Share Posted May 16, 2014 The width of the port should be constant, yours is wider after the turn it seems. Link to comment Share on other sites More sharing options...
Cj Kumz Posted May 17, 2014 Report Share Posted May 17, 2014 Use a port width of 4.5 and a port length of 26 inches (physical length 20.75).. As Joe X has mentioned keep port width constant through out the port. So in your case subtract your front and back wall (1.5inches) and also port width 4.5inches from your box depth (45inches). That gives you 18 inches for the 1st length, leaving you with 2.75. So for the second length you subtract the 0.75, meaning the back board will be 2 inches. Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!! Link to comment Share on other sites More sharing options...
Roger Peru Posted May 19, 2014 Author Report Share Posted May 19, 2014 Use a port width of 4.5 and a port length of 26 inches (physical length 20.75).. As Joe X has mentioned keep port width constant through out the port. So in your case subtract your front and back wall (1.5inches) and also port width 4.5inches from your box depth (45inches). That gives you 18 inches for the 1st length, leaving you with 2.75. So for the second length you subtract the 0.75, meaning the back board will be 2 inches. Thanks for the help, heres an update with what you described, lete m know if thats correct and or anything else that may help Link to comment Share on other sites More sharing options...
Cj Kumz Posted May 19, 2014 Report Share Posted May 19, 2014 Yah that's perfect. Looks good. You head on to building your enclosure and let's see the output . Those are great subs you gat Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!! Link to comment Share on other sites More sharing options...
Roger Peru Posted June 19, 2014 Author Report Share Posted June 19, 2014 Hey, I had to make some external adjustments as this would not fit in trunk so box is 1/2 inch lower 1 inch wider and 1 inch deeper to make up the difference so now the external dimensions are below, can anyone help with the port design for to get 32 Hz H=13.5 W=36 D=25 Keep in mind I would like to use a 45 degree in the port corner and the port height would be 12 inches. Link to comment Share on other sites More sharing options...
Cj Kumz Posted June 20, 2014 Report Share Posted June 20, 2014 Port Height 12, Width 5 and Length 25. That is about 4.6 cubes tuned to 32 Hz. Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!! Link to comment Share on other sites More sharing options...
Roger Peru Posted June 20, 2014 Author Report Share Posted June 20, 2014 Thanks again, I just modified the design with your info. does this look correct in the sense I would not need the second port piece in yellow in my old diagram. Also I want to use 45 angle in the port corner, how would this affect tuning and what width I should make the 45. Link to comment Share on other sites More sharing options...
Cj Kumz Posted June 20, 2014 Report Share Posted June 20, 2014 Yes you should be fine. On the 45s make it in such a way that the distance between the middle of the 45 and the opposite corner of the port doesn't get less than 5 inches in yo case. Just make sure the 5 is uniform through out Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!! Link to comment Share on other sites More sharing options...
