tayodell41 Posted May 16, 2014 Report Posted May 16, 2014 Does anyone have any suggestions on a good battery for a good price? I hope to matching batteries up front and in my trunk. I hope to be running a 4000 watt RMS amp in my 2001 Camry. I think the stock battery is about 600 CCAs of that helps. Can I use regular car batteries?
GSanders17 Posted May 16, 2014 Report Posted May 16, 2014 A real 4000 rms will need an alternator upgrade!
jdshott Posted May 16, 2014 Report Posted May 16, 2014 You can but its not reccomended , for the reason of acid spills and explosions. Look into saving your money and going with XS Power or Optima Yellow top. these batteries take the vibrations and constant drain and charge cycles . P.S. If you go with regular car batteries you are asking for No 1 But me paid for this stuff and NO FREEBIES so no brand names (No Free Advertisement ) A SQ head unit 6 5.25 2 X 6x9s 7804 P400.4 4001D 1 34s (Maybe time to change brand) 4 X 15" s !/0 @ 2/0 OFC Wiring :morepower1: :morepower1: ill say it like i always say it. F##K the DD-1. I don't care if you or anyone buys one. (well i do, but that isn't my point) Get an O-scope in the very minimum and learn how to use it or you are just guessing your settings like every other noob. once you master the O-scope then step up to a DD-1 or even better a DD-1 Plus.
jdshott Posted May 16, 2014 Report Posted May 16, 2014 A real 4000 rms will need an alternator upgrade! And a real charging system . or its just a wasted amp and cash! No 1 But me paid for this stuff and NO FREEBIES so no brand names (No Free Advertisement ) A SQ head unit 6 5.25 2 X 6x9s 7804 P400.4 4001D 1 34s (Maybe time to change brand) 4 X 15" s !/0 @ 2/0 OFC Wiring :morepower1: :morepower1: ill say it like i always say it. F##K the DD-1. I don't care if you or anyone buys one. (well i do, but that isn't my point) Get an O-scope in the very minimum and learn how to use it or you are just guessing your settings like every other noob. once you master the O-scope then step up to a DD-1 or even better a DD-1 Plus.
MADVIBES Posted May 16, 2014 Report Posted May 16, 2014 Not true. You'll only need an alt upgrade if you choose to play full blast for an extended period. Alts charge your batteries. If you can't find an alternative for your car and your battery drains. Just charge em at home. I have 6 group 31 on a stock alt due to the fact an acceptable aftermarket alt isn't available. Btw i have 10k rms. I can play full tilt for a decent amount. Buy two batteries and upgrade your big 3 and you'll be fine. DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
bighossf150 Posted May 16, 2014 Report Posted May 16, 2014 Deka Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
MADVIBES Posted May 16, 2014 Report Posted May 16, 2014 Bump for deka. That's what I'm running DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
tayodell41 Posted May 16, 2014 Author Report Posted May 16, 2014 Okay so just get two batteries instead of an upgraded alt on stock battery? I won't be playing music while the cars not on very much, like hardly ever.
bighossf150 Posted May 16, 2014 Report Posted May 16, 2014 Upgraded under good battery, 2 in the rear and a 270+ alt Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
tayodell41 Posted May 16, 2014 Author Report Posted May 16, 2014 Eventually I would like to do that but the whole budget thing plays a factor for now. I need to know which would be better to do first.
