islandpride684 Posted May 19, 2014 Report Posted May 19, 2014 I got the wire schematics at home if you want, it will make your job so much easier...I would run all new wires from the speakers you plan on running to the new amp....and disconnect all the speaker wires on the output of the factory amp....it sucks because the factory amp still has to be connected to run your door chimes and other stuff as well...but I would check PAC-audio.com, I think they make an adapter to do what you need...I could be wrong tho... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
HollywoodDad Posted May 19, 2014 Author Report Posted May 19, 2014 I do have all the color coded wire information, and I am running all new wires to all of the new speakers. But if I do not have to hook up all of the separate speaker wire inputs into the 360.2, then I won't do that. I didn't realize I could get away with just the left and right inputs. So what about the front and rear coming from the radio?
_paralyzed_ Posted May 19, 2014 Report Posted May 19, 2014 Just use the front. Unless you need a fader for some reason, then run both front and rear. I would just use the front inputs (simple) and set my fade level via the 360.2 and leave it.
