HollywoodDad Posted May 19, 2014 Report Posted May 19, 2014 Hello, I am a long time lurker/long time drooler of this sight, LOL. I used to be in the car audio/basshead world back in the early to mid 90's and got out of it when I had kids to raise. Now is the time to get back in. But enough about me, and on to my problem/concern. I have a 2004 Deville with the non-Bose system, but it does have a factory amplifier, I am keeping the factory radio. I have a RF 360.2 that I am going to use and here is where my concern is. The factory tweeters and front door midrange speakers each have their own channels going to them, which has me thinking they have their own signal. The 360.2 has just front L&R input which is fine, I am going to be running new components with their own crossover (5.25's and tweets), but if I run the factory speaker wire into the 360.2 from the front midrange speakers, will my tweeters still be able to receive the correct signal from the new amp and 360.2? I hope this makes since. Thanks in advance, Duke
Kyblack76 Posted May 19, 2014 Report Posted May 19, 2014 The sum feature allows the .2 to only use 2 channels IN, and OUT PUT up to 8. I would tap into the channels that would have the MOST info. AKA MOST playable bandwidth. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
islandpride684 Posted May 19, 2014 Report Posted May 19, 2014 Are you planning on running all your speakers to the new amp? The factory amp uses a 2 channel signal input from the head unit and from there to the factory amp to the speakers. Are you planning on running all your speakers to the new amp? Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
HollywoodDad Posted May 19, 2014 Author Report Posted May 19, 2014 I have a RF T400-4 that I will be using for the front and rear, mids and highs, the factory amp will stay intact and hooking up the speaker wires to the 360.2. The car does have a center channel, but I do not know what I am going to do with that speaker just yet. For the subs, I am using 2 SAv2 8's 4th order ported thru the rear deck where the factory sub was hooked up to a RF T1500-1.
_paralyzed_ Posted May 19, 2014 Report Posted May 19, 2014 Are you planning on running all your speakers to the new amp? The factory amp uses a 2 channel signal input from the head unit and from there to the factory amp to the speakers. Are you planning on running all your speakers to the new amp? You want to find the input to the factory amp, and use that as your signal source for the 360.2.
islandpride684 Posted May 19, 2014 Report Posted May 19, 2014 Nice!!! I would just run all new wires to the new amp and use the sub as the input to the 360.2 The sub is a dvc so one coil would be your left and the other your right inputs.... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
White Lightning Posted May 19, 2014 Report Posted May 19, 2014 Hello, I am a long time lurker/long time drooler of this sight, LOL. I used to be in the car audio/basshead world back in the early to mid 90's and got out of it when I had kids to raise. Now is the time to get back in. But enough about me, and on to my problem/concern.Welcome to SMD. Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
islandpride684 Posted May 19, 2014 Report Posted May 19, 2014 Are you planning on running all your speakers to the new amp? The factory amp uses a 2 channel signal input from the head unit and from there to the factory amp to the speakers. Are you planning on running all your speakers to the new amp?You want to find the input to the factory amp, and use that as your signal source for the 360.2. The 32 pin connector going into the factory amplifier Left ch + tan pin 12 Left ch - dark green pin 13 Right ch + light gr/black pin 31 Righ ch - light gr pin 30 Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
HollywoodDad Posted May 19, 2014 Author Report Posted May 19, 2014 So, with the 360.2, all I need is the left and right channels going in and that's it? I don't have to hook up all of the separate L&R front/rear/sub wires into the .2?
_paralyzed_ Posted May 19, 2014 Report Posted May 19, 2014 So, with the 360.2, all I need is the left and right channels going in and that's it? I don't have to hook up all of the separate L&R front/rear/sub wires into the .2? Nope, you don't need all the separate inputs assigned. You can output all 8 channels with only a 2 channels input.
