Mounting amp on box
Cj Kumz
Hey people. Quick question here. Okey I have seen many builds where people mount the amp on their boxes, but just a thought here doesn't the direct vibration from the box have any effect on the amp?? Just wanna be sure in case of anything :) lol
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
5.5 cubic feet box with 10 inch port @ 38hz
I live to hear the Bass drop!!!
It's not a good idea IMO but, if you can find some thick enough rubber to put under the mounting feet that may be enough to absorb SOME of the vibrations.
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
I could be wrong but the amp being mounted to the box isnt going to pick up much more vibration than if it were sitting next to the box. If a box is heavy enough i dont think it will transfer too much vibration from the sub.
In some cases yes, if the box is thick enough and braced well. I still don't think it's a good idea, unless you have no where else to put it.
I'd rather be safe than loose equipment over carelessness.
oh lawd.
I never recommend mounting a amp to the box. IMO ... And there are a few more threads on this subject as to why or why not.
No 1 But me paid for this stuff and NO FREEBIES so no brand names (No Free Advertisement )
A SQ head unit
6 5.25
2 X 6x9s
7804
P400.4
4001D
1 34s (Maybe time to change brand)
4 X 15" s
!/0 @ 2/0 OFC Wiring
:morepower1: :morepower1: :morepower1: :morepower1:
ill say it like i always say it. F##K the DD-1. I don't care if you or anyone buys one. (well i do, but that isn't my point) Get an O-scope in the very minimum and learn how to use it or you are just guessing your settings like every other noob. :) once you master the O-scope then step up to a DD-1 or even better a DD-1 Plus.
IF your enclosure is securely mounted, there should be very little vibration....
Properly built/braced is more important than box being mounted
I've done it lots with no problems but do at your own risk
Team Flex Issues
Thanks a lot guys. With the setup I have I seem to have no other option. But I wanna try the rubber base method. What is the best type of rubber I can use?? Or anything else apart from rubber??
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
yea....that too.
  • Who's Online   0 Members, 0 Anonymous, 775 Guests (See full list)
