huge problem..Memphis mojo amp.
jarball25
i have 2 memphis mojo 4k amps. one amp shuts off so i decided to take voltage reading across the two (Troubleshoot) when both amps are powered down i read across the power inputs and receive 14.95. When the amps power on with no load (speakers disconnected) i receive a voltage of 14.87 on one amp and 13.12.
i checked all my connections and took resistance readings across the all to make sure that wasn't the problem and sure enough that was not the problem.
is this a sign of early amp failure?
Have you check the amp ground?
2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
you're using a ground distribution block? get rid of it. amp -> wire -> frame. nothing more.
  • Who's Online   1 Member, 0 Anonymous, 759 Guests (See full list)
