What if an enclosure is too big for the subs?
Ektro
23" tall, 42 wide,
how deep,
port height
port length
how many layers is that baffle?
10338830_1419398611671192_87487340086215
double baffle box. Port is probably 21in long, 5 wide. butttttttttttt there is this photo as well
1381557_1419398171671236_203303712265490
The box is together so can't really measure much now.
The builder used a box design software to make sure it could be tuned at 33-35hz but he worried that it will be too big for XL subs...not the port just the cubes in general...
He took the design I came with and tried to tweak it with his software.
I just hope this box turns out really well...really don't want to have to sell my XLs to try and get lvl 5s so I can use the damn box!
That port isn't 21" long.
Come on dude, take a tape measure and measure the dimensions. Height, depth, width, port width, port depth. We can't figure anything out without the dimensions
You can easily take a tape measure and hook out it to the port extension to see what the depth is. You can also measure the 3 dimensions of the outside of the box. Height, depth, width. Pretty easy stuff man.
Also, who designed it?
If your box is as far off size-wise as it sounds like it is your best bet may be to just start over. Another idea is you might be able to cut 6", or however many inches it needs to be, off the bottom and then glue another bottom on it to get the size down. You will almost definitely have to make some port modifications to get the tuning right, but with the bottom off that may not be too tough to do. If it were me that's probably the route I would take.
Regardless of the design issues, I'm not impressed with your builder's skills.
Builds:
Trying to figure out if lvl 5s need a bigger box then XLs or the same.
I really like this box, worked so hard on it!
I think he did good.
