sup everybody. having some problems with hissing noise coming from 1 channel on my brand new sundown 125.4. my tweeters are hooked up to that channel and make a fairly loud hissing noise, louder then the other tweeters and distort when the other tweeters are just fine. pretty sure its the amplifier because i tried everything else that i could think of. anybody have this problem before and can confirm my assumptions that its one faulty channel. thanks
Could it be a bad rca?
truthsayer
if you ran your power wires and rca's in the same route it sometimes creates a noise "ground loop" you can buy an isolator "PAC SNI1"
to dampen the noise or rerun your rca's in a different route. although if you have a weak set of rca's that can also be a problem. might want to buy a higher end set.
it still makes the noise when i pulled out all the rcas from the amp. and they are brand new KNU krystal kables, not super cheap rcas
Your gains are to high or you have a grounding issue somewhere.
truthsayer
i have my tweeters on channels 3 and 4 and the gain controls both, if my gain is too high wouldnt my other channel tweeters be hissing as well? because they didnt have any noise coming from them. also grounding issue you mean the actual ground wire to the amp? because the power and ground wires are less then 12 inches coming straight from a 16v battery bank.
  • Who's Online   0 Members, 0 Anonymous, 608 Guests (See full list)
