ford focus best ground spots?
I have a 2001 focus zx3 hatchback and was wondering the best places to ground the wires. Will be doing the big 3 upgrade as well. Thanks.
Is it a unibody? if it is ground batt and engine to shocktower
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Yeah unibody. I'll be doing a ground from passenger side tower to driver side tower, alt grounded to pass side tower front battery to driver side. Then rear batt to one of the 2 sides (whichever ends up as the closer side).
I'll have 2 0gauge runs pos with a 250 amp singer alt, external regulator adjustable, and running 4k rms roughly.
if voltage isn't doing good I'm going to run 2 0gauge grounds front to back.
as for batteries I plan to take out the stock holder and see what I can do to fit a group 31 and at least one group 31 I the back all agm of course
with all that I'm hoping to hold 13+ volts on music while driving down the road.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 16732 Guests (See full list)
