18" Fi SSD Trunk Box Help
Hello. If you checked out my topic yesterday then you know I was thinking about some 12s but the more I talk to this guy (from craigslist) the more shady the deal seems. I think one of the two subs is blown. Anyway, I'm just gonna keep the SSD I have. Its got the upgraded coils so it takes 2000 watts RMS. Max height is 15", max depth is 25", max width is 40". Its going in the trunk of an 01 Camry. This will be my first real box build so I need some help with the design. I would like to port it so the port is firing into the car through the hole behind the rear seats. Any help is appreciated, thanks.
i wouldnt try to fit this in the trunk, you could sell it and buy a ssd 15 and be louder, maybe even 12, you need to get it ported properly and also placed in trunk properly. 18 firing up is not optimal at all.
It does fit in the trunk. I've already tested. I know its not ideal but its what I have to work with.
this is one of those things you should just do with out saying anything because most on here, including me, will tell you its not ideal. Your end result may turn out great though who knows!!
If your gonna do something....you might as well do it right..
That being said, give your max trunk dims and wait for a member named JOEX to tune in... If he says don't do it.... Don't do it.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
I know I'm hoping for a design so I can do it right. Max dimensions are in first post.
  • Who's Online   0 Members, 0 Anonymous, 665 Guests (See full list)
