MatthewBigBossWilliams Posted June 6, 2014 Report Posted June 6, 2014 So I put my old system back in my car until the new one comes up. Well I wired everything back and got a better ground. Now my headlights dim and my battery reads 13.8 - 13.9 at idle and goes down to 12.9. After I ran it again, I reved 2000 rpm and went from 13.9 to 13.3. The big 3 has not been done and I can't upgrade the alternator right now. Should I just turn the amp down? Do you notice anything else I haven't mentiond?
Swordlordboy1234 Posted June 6, 2014 Report Posted June 6, 2014 Do the big 3 ASAP... Prob a cheap volt meter giving you bad read outs. The lights on cars are 12v. So when they go below 12v they dim. Meaning your not 13.9 like you think. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
Bump4life Posted June 6, 2014 Report Posted June 6, 2014 Do the big 3 ASAP... Prob a cheap volt meter giving you bad read outs. The lights on cars are 12v. So when they go below 12v they dim. Meaning your not 13.9 like you think. when you have any voltage drop, your lights will dim not just below 12volts OP if you hold 12.9 you are fine. no worries. do the big 3 and i bet you will have increased performance. Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
MatthewBigBossWilliams Posted June 6, 2014 Author Report Posted June 6, 2014 Hey man post again for me. your posts says 3,666 and it creeps me out lol but alright I appreciate it. I will have to go underneath to hook up the wiring myself
MatthewBigBossWilliams Posted June 6, 2014 Author Report Posted June 6, 2014 Do the big 3 ASAP... Prob a cheap volt meter giving you bad read outs. The lights on cars are 12v. So when they go below 12v they dim. Meaning your not 13.9 like you think. when you have any voltage drop, your lights will dim not just below 12volts OP if you hold 12.9 you are fine. no worries. do the big 3 and i bet you will have increased performance. I see what you are saying. I checked with a volt meter. Rear battery is 13.8 while front battery will read 13.6.
Bump4life Posted June 6, 2014 Report Posted June 6, 2014 damn. the devils post no more!! Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
