- GM / Chevrolet Tech's? DRL Problem That Is Likely Something Very Simple To Remedy ...
I have a 2003 Monte Carlo SS, ... 3.8L w/ 55,000 miles on it, & has never
seen a single snowflake, nor the accompanying "salt 'n cinders" here in
Central New York.
The Problem:
The PASS side DRL (high beam's on this car) runs dimmer than the
DRIV side. When I use high beams, they work flawlessly, ... &, yes,
they are identical bulbs - Philips Diamond Vision 5000K 9005/HB3's.
During the day, I chocked tires, & applied the parking brake, then put
it in gear to activate the DRL's.
I took the DRIV side bulb out, & used a DMM to measure voltage right
at the fixture, & it read just shy of 6v ... appears they run at half-brightness
as DRL's, ... then I unplugged the PASS side bulb, ... The DMM read just
shy of 3v. I used another DMM to confirm the voltages.
What a head-scratcher at that point.
I asked some folks in a Monte Carlo Forum I am part of, & someone told
me to check a particular relay under the hood.
I found the relay with ease in the upper fuse box, & there happened to be
an identical relay right above it - that one runs the fuel pump - so I swapped
them out to see if the lights would work, & if the relay was bad, then the car
would also not start because it would not activate the electronic fuel pump.
I hit the key, & the car started. Ugh.
... & the DRL's were still messed up. I grabbed the relay that was running
the fuel pump - the one the originally ran the DRL's - & I pulled it out, & the
car quit running almost immediately. Relay problem? No, Sir.
Anyone have any ideas? I am mechanically inclined, especially when I get
Pop involved.
Thanks for anything, folks.
Zeke
'14
2003 Chevy Monte Carlo SS
Vehicle Details & Mod List: http://www.stevemeadedesigns.com/board/garage/vehicle/1703-chevrolet-monte-carlo-ss/
Audio Build Log: http://www.stevemeadedesigns.com/board/topic/143276-2003-chevy-monte-carlo-ss-audio-build-ib-build
Pioneer FH-P8000BT
Infinity Kappa Perfect 6.1
Fi IB3 (Two 12", 2-ohm SVC)
RF T400-2 & T500-1bdCP
MechMan S Series 240A
XS Power D3400 & D975
I skimmed through identifix to see if i can find anything about the one light being dim. Came up with nothing.
The most i was able to find was about was the blower motor, DRL and HVAC not working, Most fixes was Ignition switch, then body control module, then headlight switch.
Last thing i found was a few fixes for highbeams not working, and the fix was cleaning/repairing the grounds for headlights.
If it's worth building, it's worth over building.
Thank you for shooting some things my way ... I have never heard
of "Identifix" before, ... definitely will check that out for a plethora of things.
As far as the other stuff you brought up, everything else on the car works
perfectly, & like I said, the bad winter stuff has never had a chance to
corrode stuff, etc., ... although I am absolutely cognizant that stuff can still
happen, & anyone of those issues you listed could be an issue ... & I am
going to start checking through as many of them as I physically can, ... I
just know when I take it, IF I have to, to the Chevy Shop, it is clearly elec-
trical, & it is right around $96/hour - both diagnostics, & fixing. What I hate
is that they really will not tell you (me) what is wrong (& I pay appropriately),
& then I take the car & get the parts & fix it myself ... It is always like a big
fucking secret, & if your are not going to let them fix it, then you are given
info that just has you chasing your tail forever.
Ugh.
I do not know.
But, again, ... I greatly appreciate you replying, Sir.
... & let us see if anyone else does & has a same or different idea, ... ALL are welcome, folks!!
Zeke
'14
Pioneer FH-P8000BT
bump
Zeke
'14
Pioneer FH-P8000BT
I had this issue with my truck, and while i know it;s not the same vehicle, it it was the same problem. (but on drivers side). My issue turned out to be a ground issue.
Good luck, i know these type of issues get to be annoying.
truthsayer
Double Double, Ugh Ugh!
Zeke
'14
Pioneer FH-P8000BT
