Schliep96 Posted June 9, 2014 Report Posted June 9, 2014 I'm looking for the right amp for my system, i have 3 Rockford Fosgate SVC P1S4-15's rated at 250 RMS and 500 Max each. Wired together comes to a 1.34 OHM load. What should i look for in OHM load and wattage rating on the amps?
RooTxBeeR Posted June 9, 2014 Report Posted June 9, 2014 If you need 750 watts @ 1.33ohm I would say look for a amp that puts out around 800 watts if not a little more at 1 ohm. Check out http://ct-sounds.com/at900-1d-amplifier/ or even the 750 if this is to much On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5
youngbass98 Posted June 9, 2014 Report Posted June 9, 2014 you could probably get away with a Rockford prime 1200 or a soundqubed if you set your gains right 06 monte carlo 2 12 rockford p3s soundstream rubicon 2500 crescendo audio mezzo 6.5 ct sounds 125.4 execution audio and shca wiring 2 xs d3400 on stock alt
