belva amps any good?
iG_JAXX
I just got one yesterday to play around with. Will hook it up today and let you know. I bet it will be better then the brz2400 I have now.
Your going to spend a lot more then 300$ for a amp that will do 2.5 3k @2ohm
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
is the belva bb5000 any good of any amp? looking for a new amp for my 2 Fi ssd 15s
it has a 200 amp fuse, so 200*10 [volts] = 2000 watts. - 350 watts for clean power = 1650 watts clean. Maybe.
1997 subaru legacy outback
Four 15's in a almost wall
Rockford Fosgate t2500-1bdcp
Rockford Fosgate T400-4 on tweets
Rockford Fosgate T400-4 on highs
Rockford Fosgate T400-2 on midrange
Rockford Fosgate T400-2 on midbass
Optima Yellow top batteries
270A Singer alt (working on a bracket for a second)
Lots of Second Skin
It has a 300 amp fuse
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Certified 1% Distortion: 1 Ohm - 1,718W @ 12.18V
Uncertified to Clipping Point: 1 Ohm - 2,091W @ 12.19V
Dynamic Burst Mode: 1 Ohm - 2,238W @ 12.91V
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
oh.
Lots of Second Skin
thanks everyone. and i have around 300 . need about 2 to 2.5 k rms. also subs are dual 2 so they are only at 2 ohms
Fi coils if i recall are either .7 or 1.4 ohm. So if you have 2 dual 2 (1.4) . You can run a final load of 1.4 (parallel-series).
And with your budget of only $300, i would go with the soundstream Ta 3000.1d. Out of your options listed that would be the best.
truthsayer
I've read it calls for a 200-240AMP external fuse, so I'm not sure where 300AMP was ever mentioned. If it were in fact 300AMP, then the Belva should do close to it's claimed 3K, though no telling just how clean the power would be. With adrawing 200AMPS, it'd produce somewhere in the neighborhood or 1700-2000RMS depending on efficiency. Again, no idication of how clean this power would be.
If it's using a 300AMP inline fuse and still fails to produce more than 2K, that's one inefficient class D amplifier.
  • Who's Online   0 Members, 0 Anonymous, 656 Guests (See full list)
