Camp Soundmexanxdan- 4 X 15in Fi Ssd
my opinion, just keep doing layer by layer.. I got at least a 1/8 inch thick inside my box maybe a bit more, 3 semi thick coats for sure.
just dont go to thick per coat otherwise when the resin is curing it will crack depending on how much hardener you use it gets kinda hot.
Its not going to build strength untill you actually use fiberglass mat. Everyone puts resin in there boxes for better airflow not for strength.
Car-96 blazer 4 door
Amp- Us-Amps M2D2
Front stage- Infinity Reference Comps 6.5
Subs- Undecided open to all offers and opinions
You had to have it all
Have you had enough
You greedy little bastard
You get what deserved
When all is said and done
I will be the one
To leave you in your misery and hate what you have become
should have some more work done this evening, more resin will be added and the port holes will be cut....sucks not having a lot of time to get stuff done...and having to do it little by little
Sound Mekanix - Dan
Team Fi
Team Kinetik
Team Sundown
Ascendant Audio
Sound Mekanix SPL Design Team
some more pics of the build....
my buddy mike grinding down some pegs so the box can sit level......
Posted Image
what happens to a rag when you dont move it out of the way...dont ask why we didnt move it....couldnt tell ya, lol .......
Posted Image
100ft of 1/0
Posted Image
Posted Image
Posted Image
Posted Image
Sound Mekanix - Dan
Team Fi
Team Kinetik
Team Sundown
Ascendant Audio
so what are you going to do if the 100sqin total of port for (4) 15"s isnt enough
even if it is 18cuft net, thats only ~6.25 sqin of port per cubic foot... i thought it was suppose to be minimum of 12cuft
or are u trying out the aeroport theory that the reduced velocity means u need less port surface area?
either way, should slam, cant wait for vids :)
it'll have to be enough....even if i wanted to build another box, dont have any more room vertically or horizontally....we figured we'd make the box as big as possible....another friend of mine has huge table saw that we can always take an inch or 2 off the top with...we'll just have to see what happens
Sound Mekanix - Dan
Team Fi
Team Kinetik
Team Sundown
Ascendant Audio
