superCaps vs no supercaps vids. stock alt
So for 14v batteries I would want banks of 7 right ? Doesn't that put the cap voltage at something absurd like almost 19v ?
Even at 6 caps you are at 16.2v. How do these things recharge when the alt set point is lower than the caps ? Help me understand but I like what I am seeing.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
yep banks of 7 would do. it will lower your capacitance of the banks so id recommend 3 banks per 5k if using 7 per bank. they only charge to the setpoint of your voltage regulator.
caps dont have a set voltage like batteries. you can use them from .0001 volts all the way up to their max rating. if you have a bank of 7 2.7 volt caps, the HIGHEST voltage you can charge is 18.9 volts. anything under 18.9 volts is fine. I would personally recommend you only charge to 18.2 with banks of 7 to give yourself a .1 volt margin if your bank isnt evenly balanced. and for 6 cap banks i would charge no higher than 15.6. charging over the max voltage or near it can be dangerous if bank isnt balanced. but you never ever charge over a banks max rated voltage.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
