Sub wiring will be 8ga one wire directly from each output to each direct lead. Hence the quad outputs from toolmaker posted earlier.
973BC5E2-61FA-4199-8FF4-554B72B0535F_zps
6C67596A-E3B5-453B-8D31-BD95EB3E7FD9_zps
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
Shca ring terminal fuse holders and 300 amp fuses for all the rear bank to amp input wires.
16A5A3A5-7FD8-4339-B757-6DD2B7E846F9_zps
B80FBD0C-3352-4A8C-84CA-773E47C2AFBB_zps
54DC3C0F-4978-46DD-881D-145A99DEC89E_zps
DA1E6030-42FD-462D-88F4-2F4E21E55322_zps
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
These are probably the only wiring parts I'm
Using that are not shca. That's because they didn't offer dual holders and I for these on Facebook for like $5 shipped iirc. They will be used to fuse the two positive runs front to back.
A67D1F83-FE3A-48C5-B598-8EBB89804E1F_zps
3E212B0E-B0FD-4D9C-8E8B-0BD62A98B93B_zps
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
Removed my avh-x4500bt and will be installing this. Cody convinced me to try my hand at running active front stage. I don't even want to say how good of a deal I got on this. It would make people sick.
69802A41-79B6-4115-9921-BD86BFBBD0F2_zps
0A0672C8-4888-40B5-85CD-B64CAACFAF2A_zps
CF17DF02-074A-4B58-8A32-573FA0CFB1E6_zps
8AF86181-A5DF-40B7-932F-82BBCFF47A5B_zps
2AF6FF7E-9C65-4098-A9B2-570AC953A918_zps
81827AA0-C7B9-4A15-B8EE-84822D6627CF_zps
8D5E3C10-91ED-4706-B00C-66A49396CCF5_zps
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
Box will have a removable port. Burp port is permanent in box and the daily/demo port bolts inside the burp port. Here is the specs with just he burp port in.
A99851BD-09F8-4233-9899-05D36ADF29FA_zps
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
Here is specs with the daily/demo port in. I had to get very creative to get the low tuning I wanted combined with the port area I wanted. The reason that was hard was because with a max box width of 40 inches and two 15s I only had 7 total inches of port width to work with and obviously the port width and height is less in the daily/demo port than the burp port since it has to bolt inside the burp port. I accomplished this by only using 0.125 inch thick walls on the daily/demo port. Who can guess how I made that possible?
7D49442D-9A3C-47AD-98FD-AC04FD3E3AA4_zps
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
Still waitinf on a couple more packages to come in. If I'm off work Wednesday like I should be I'm going to try and knock the box out.
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
Oh also the sub amp is currently at toolmaker getting a new acrylic back plate cut. He did one for me then said he waned to redo it because the fan slot was not perfectly centered over the fan. I'm cool with that though I'm glad he is a perfectionist. Should have it back late this week.
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
Lots of good gear.
;-) thanks man that bug hit me and a 145 just wasn't going to cut it anymore lol.
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
