Aj11 Posted July 2, 2014 Report Posted July 2, 2014 not to add fuel... but i wouldn't run those amps. yea they kinda do rated... but there power hungry dirty Lil shits. for a couple extra bucks you Can get more power that will be cleaner and use less juice doing it. you asked for advice and everyone here would say no go else where for the amps. but if you want to use them no one Can stop you... only advise against it. other then that you look.pretty good. run ofc and deadner deadner deadner! look.into ct sounds.or sq. either amp will be much better without breaking the bank!the ct 1400.1 will do 1800w for about $350/$400 i have 2 strapped at .5 on a 110amp alt and at 3/4 of full tilt i stay in the 13s nough said jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
redwolf2 Posted July 2, 2014 Author Report Posted July 2, 2014 not to add fuel... but i wouldn't run those amps. yea they kinda do rated... but there power hungry dirty Lil shits. for a couple extra bucks you Can get more power that will be cleaner and use less juice doing it. you asked for advice and everyone here would say no go else where for the amps. but if you want to use them no one Can stop you... only advise against it. other then that you look.pretty good. run ofc and deadner deadner deadner! PMed Skippy and edited my posts. Just a misunderstanding on my part and I apologize for jumping the gun on that. Got tired of response on other sources of just brand hate. Forgot there's actually knowledge here (thus why I'm here) Can you make any recommendations?
MrSkippyJ Posted July 2, 2014 Report Posted July 2, 2014 I think the hifonics will do fine, not my first choice but it will work. If I were you though, now that I realize you don't have the amp yet, I would save up a bit more and go with some SoundQubed amps. Very reasonably priced and really do perform better than the hifonics amps. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
redwolf2 Posted July 15, 2014 Author Report Posted July 15, 2014 So after doing some measurements, I should have around 6.4 Cubes to play with. (17x40x17) That's quite a lot for a single hdc315 isn't it? Any suggestions on whether or not I should alter my sub plans? Thanks
