Mk1 Golf box build assistance for Pure SPL
Good day guys/gals,
I'm relatively new on the forum and would like some assistance and advise on a new build of mine.
Dimensions to work with 940mmx400mmx430mm
Subwoofers 2x SA 12's D2's
Amplifier Taramp HD8000 2ohm
Batteries 5000 CCA x2
Any ideas and suggestions welcome, recently did 148.9db in DB drags looking to improve my number a bit.
Try this "cube" out , i´ve burped 149 legal with only a 2K and 2 loudforce 8512s wich are similar subs ;)
Box:
16.5" x 16.5" x 16.5" , 1 sub up and the other one facing forward, external 8" aeroport 18" long with 13.5" flares on both ends, should burp over 150 with your equipment no problems at all, if you recone those subs to dual 4 ohms and wire the amp at 1 ohm with a couple of batts you should burp over 151 easily
Thanks for the response, i will give it a bash and get back to you, also note that the cars resonant frequency is 56hz, any other suggestions, at what frequency were you burping? would you mind sending me more pics of how your aero port is mounted, [email protected]
Is it actually 56hz or is that where your current enclosure is peaking?
that box has been tested and used on a lot of cars now, peaks at 56-59 hz depending on cabin and power we use, should work nicely on the golf
Hi Guys/gals,
Thanks for the help and advise...
just an update after building and testing the box with entry level woofers first this is what i achieved.
1st test amp gain 75% no LPF 149.1
2nd test amp gain 75% LPF about 30% 149.7
3rd test amp gain 75% LPF about 45% one click before amp goes into clipping 149.9 i have some pics as well.
Not sure how to post the pics though.
damn, that´s weird! i mean, if you are burping a single frequency, why should the lpf affect the score so much? i always set the subsonic on lowest point and lpf on highest point for spl :o
  • Who's Online   0 Members, 0 Anonymous, 775 Guests (See full list)
