static like crackling
flexinfusion
So to begin ill give a break down of my stereo as it sits right now
Pioneer hu
Rf t1 components in front doors
Kenwood 5x7 in rear doors.
So my issue im having right now is im getting crackling and static like sound at higher volume. And when I turn my ignition on my rear left speaker pops. I believe im hearing more of the static crackling noise out of my tweeter more then the mid. I dont think their blown because I just took the components out of my old car and put them in my truck now this. And a little back story I had rf 2 ways in the front doors and this last week they started sounding snappy like crackling at volume between 38 and 62 on my deck. So I thought they were blown thats why I replaced them with the components and now all 4 speakers sound like this.
Can anybody please help.
2009 fusion
Steeda Mods kenwood DDX418
RF T1675-s Front doors
RF T165 Rear doors
OLD SETUP:
ab XFL 1222Audiopipe 1500d
2.5cu ft 32hz
Distortion, clipping
truthsayer
have you checked connections
on the hu itself ground, power, and speaker connections
made sure the rcas aren't loose
tried changing the pico fuse on the back of the headunit
is bass boost on?
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
Have no amp. Check all the hu wires none loose. Radio still works and all so I didnt think to check that small fuse.
2009 fusion
RF T165 Rear doors
OLD SETUP:
2.5cu ft 32hz
Im also not getting and mid bass out of the mid driver.
2009 fusion
RF T165 Rear doors
OLD SETUP:
2.5cu ft 32hz
YOu might have to ground the rca's in the back. Just a guess, I've read that alot of people did this pioneer hu's to fix noise problems.
Ground rca's? he is not using an amp.
truthsayer
Could it be my body to chassis ground
2009 fusion
RF T165 Rear doors
OLD SETUP:
2.5cu ft 32hz
This and what ohm load are the speakers running on the head unit? What model Pioneer?
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
9600hd pioneer
2009 fusion
RF T165 Rear doors
OLD SETUP:
2.5cu ft 32hz
  • Who's Online   0 Members, 0 Anonymous, 999 Guests (See full list)
